0 Members and 1 Guest are viewing this topic. Read 55139 times.
Why ask me? Do your own thinking.Cheers.
The mackie hr824 provided me with the least amount of musical enjoyment of any others i have owned.
By all means, I agree with being skeptical. I don't expect your belief in my appraisal, as your evaluation doesn't change my experience. However, I do expect your respect that my appraisal was honestly given. And if honestly given, how am I to deny what my senses tell me? Will you also tell me that I cannot tell a Steinway from a Baldwin if a microphone fails to confirm my differentiation?Scott
One has to also consider solid wire VS stranded wire as micro arcing occurs between strands. Stranded wire can have a softer, smeared sound than solid wire. So right there we have a sonic difference in wire.Cheers.
Ethan, you are doing your company a great disservice by admitting that you do not at all understand what your client base is after, while making your disdain for them perfectly clear.
No amount of wishing and believing can make this true.It just does not happen.
You seem to be completely disregarding that we know our senses are very unreliable.
If that were truly the case, we would have all been eaten by lions, tigers & bears a long time ago. A person may thou, in these modern times, to not have had the opportunity to train to bring out the potential.dave
Although in his book "This is Your Brain on Music," Daniel J. Levitin makes a good case that music is more deeply engrained in our DNA than we ever thought.
So far, no one has shown measured differences in power cables that would account for the perceived sq variations discussed here, so...
And trying to measure it with the bath room scale is not much more ridicules that some of the things I have heard.
The differences are in the noise floor.
All of you guys that are looking to measure some difference needs to figure out what to measure for and how to measure it, and stop trying to measure it with your bath room scale, then claiming there is no difference. And trying to measure it with the bath room scale is not much more ridicules that some of the things I have heard. You guys are missing the boat.
Does that mean the differences are below the noise floor? If that's the case, then that would be a logical reason why they cannot be heard...
no, it means the differences are in the noise floor, and eliminating the noise, lowers the floor, and the music sounds better. i remember a few years ago, when i was modding my art di/o dac. i did it in stages, and each time, the noise floor dropped, and more music was revealed...doug s.
Ok, so if I understand correctly, it should be demonstrable through measurements of the resulting noise floor that certain power cables contribute less noise? That seems reasonable. Anyone have a link?
