sp1.7
0 Members and 1 Guest are viewing this topic. Read 2019 times.
DJ OTTOmatik
sp1.7
« on: 5 Sep 2011, 11:18 pm »
hi just wondering how to do a factory reset on a sp1.7 with version 44a,  is this the latest version.  i would also like to get a black faceplate and knobs for my 1.7 to replace the silver.  does anyon know how much this costs
  • The Demo is Everything!
    • http://www.bryston.com
Re: sp1.7
« Reply #1 on: 6 Sep 2011, 12:21 am »
Hi
Contact service - [email protected]
James
Phil A
Re: sp1.7
« Reply #2 on: 6 Sep 2011, 12:22 am »
From memory 44e might have been the last
DJ OTTOmatik
Re: sp1.7
« Reply #3 on: 6 Sep 2011, 12:49 am »
what are the changes from 44a to 44e, anyone know the cost.  does anyone know if there is a factory reset remot code, i think i found it once in here but cannot find it again.
Phil A
Re: sp1.7
« Reply #4 on: 6 Sep 2011, 11:45 am »
I believe they may be at the Bryston website under Technical Info.  There were changes in bass management among other things.  When I had my SP1.7, I think 44d is the last one I did as there were just minor changes
DJ OTTOmatik
Re: sp1.7
« Reply #5 on: 9 Sep 2011, 06:28 pm »
ok so i have called twice, and emailed about the faceplate, i belive the person i am trying to reach is mike pickett.  i still have not heard anything.   does anyone know if there is a factory reset code.  my nephew was playing with my remote and changed things that i cant seem to fix or find... i would like to start from scratch.  someone please help
brucek
Re: sp1.7
« Reply #6 on: 9 Sep 2011, 07:03 pm »
I don't know the codes for the SP1.7, but for the SP2 the Restore Factory Defaults code is 254.
brucek
Phil A
Re: sp1.7
« Reply #7 on: 9 Sep 2011, 07:04 pm »
brucek
According to this thread - that should work
http://www.audiocircle.com/index.php?topic=54235.0
