0 Members and 1 Guest are viewing this topic. Read 13514 times.
Here's an idea.........do as Bob in St louis did.........and pick up an AR-XA. Bring it to Columbus, and I'll show you how to go through it. Maybe the act of actually getting your hands in ahead of the music will help you also. There is a certain ritual about vinyl that can't be replaced with a CD. Just as there is a certain something about vinyl sound that can't be replaced by CD..........BUT There also is a certain something about when you drop the rock and smile to yourself knowing you "built that sum-bitch" yourself.I just finished an XA early Friday evening. My neighbor came by for a listen. About half was through Sade's Smooth Operator he made me a pretty generous offer. An XA can charm the socks off of you.
Taking the next couple days off and going to go have some fun. Then back to work and tt hunt.
I have owned 4 different AR-XAs a different times. 2 have been made into ARCom and ARMod. While some may fancy this table, it's a crap shoot to find one that doesn't have a weakened motor and there are zero replacements available, unless you want to put an Origin Live DC motor in it.While the table does have many fine sonic qualities, it is not a table for a newby looking for plug and play. They simply don't exist unless some one you know has correctly repaired and calibrated it.On another note, I have to ask what sonically inferior sounds come from a Technics SL1200MKII?As someone that owns (or has owned) many, many turntables, The Technics (if set-up properly) can sound damn near the same as my VPI HW-19jr, or my Sony PS-X5, X7s or the AR mods.Technics didn't know what they were doing, that is why they only sold 3.1 million SL1200s, almost all of which are still in use today.Wayner
...........OK, where do I start? Unless the motor has a shorted coil, normally it's the pole piece after 40+ years that loses some of its magnetism. That can be cured. The spindle bore in the motor gets dirty. Not an issue, neither is better thrust washers and resetting the top bushing. I have 3 to be rebuilt.I make a thrust bearing for the(platter) spindle well and tonearm well. The tonearm gets taken apart, rewired. The brass barrel has the delrin bearings removed and sapphire ones installed. It then gets fused to the steel collet. The tonearm tube ( as mentioned in another thread ) gets damped in three spots. Vertical friction comes in < 10mg. Jelco lists <20mg, and Linn lists <50mg. The suspension system gets repaired........and that is where 90% of the timing and sustain takes place in a suspended table. Of all the "other people" mods I've seen on AR tables, nobody really addresses some pretty basic issues in the suspension.I'm not trying to disagree with you Wayne......just pointing some things out I've found.I don't own an XA as an everyday table.....my modded ES-1 is. Those can't be had after I'm done with them for entry level money. My XAs can. I firmly believe at today's entry level money, a properly modded XA will run with any of them. I recieved a pretty nice note from a audio salesman regarding the parts I sent him for his EB101, and then what he ran it against.
