0 Members and 1 Guest are viewing this topic. Read 13581 times.
Is the sl 1200 for sale?My local guy says they sell as soon as they come in for $300. Kids keep buying them to dj. He says the price will rise since they have discontinued the table and the demand is still there.I have a friend that is pushing the new Rega p1. He says for 450, you get a 300 arm that can be saved for many a table.... Will be making the first move by the end of the week.
hallo,i still think the Thorens TD 160 would be the best bet for you.they run and run with almost never any problems, basically foolproof.if you want something different, then this will be better than most.http://www.audiogon.com/cgi-bin/cls.pl?anlgtabl&1308939141&/Kenwood-KD-650sell the cartridge and you will get most of your money back and put a Grado or Ortofon cartridge in its place for MM input on your amp.this is nice and you can probably offer a bit less for it, then you only need a cartridge.http://www.audiogon.com/cgi-bin/cls.pl?anlgtabl&1308532615&/Denon-DP-60Lthis will also do you nicely.http://www.audiogon.com/cgi-bin/cls.pl?anlgtabl&1308495498&/Harman-Kardon-T55corhttp://www.audiogon.com/cgi-bin/cls.pl?anlgtabl&1308434385&/Rega-P2this is basically a Rega P2 but with another name...http://www.audiogon.com/cgi-bin/cls.pl?anlgtabl&1307929357&/Rotel-RP-900have fun choosing,bas
I have found my table, it only took two days and two tables, but i settled on a Townshend Rock Elite turntable. I now have to find and arm and cartridge because his stuff was WAY out of my price range. But I can say that I hit both the look and sound I was looking for at a price that was half what my budget would permit. Now I can spend the rest on the arm, cart, and pre????
What an INSPIRED choice, Andy I owned one (I think maybe it was a Mark II) in 1988-89 and it made some of the sweetest sounds I've heard at my house. With a Grado at the helm (Grado's enjoy fluid damping and the Townshend has it in the best place I can think of - at the end of the 9" arm) it kicked out some serious tunes.It had an old Helius Orion as the arm. A nice Rega RB-251 and a <$200 Grado will have that deck singing - and, you, too Bass that put CD to shame (still would I think) and smooth as silk with the oft-ragged Grado tames with fluid damping.Setting in up on feedback resistant base or feet is a MUST. The masonite/concrete Max uses for the plinth does trap a fair amount of energy in it. Enjoy, John
