Not in slightest, if you recognize that there are many MANY pathways to achieve the goal of a pleasurable listening experience. Why do you think people preach so much about system synergy? Who would want to put monster truck tires on a ferrari, or racing slicks on a Land Rover? I can think of plenty of speakers that would sound magical with tubes and like $hit using solid state. A 16ohm impedance lowther will certainly restrict a SS amp. Also, just because tube amps are in the minority, and therefore the majority of speakers are designed with solid-state in mind, doesn't mean that tubes are inherently limited. ...
Wrong Kevin, I am not biased against or in favor of any technology, as long as it makes good music. Frankly, I don't much care how it's made, as long as it works well.
It's true I am much better acquainted with solid state then with tubes; small wonder, ever since I took up soldering in the late 60-ies, I have worked with SS, not tubes.
I have also heard some tube audio gear which I thought was truly wonderful, outstandingly good, just as I have heard some SS stuff for which I'd say the same. And the opposite, of course, both tube and SS stuff which was bad, poor designs.
My only objection to tube audio has, in fact, nothing to do with actual tubes, but with the marketing hype behind it. These days, we are told from many sources that if it's not tube it doesn't really work well, it can't because only tubes are good for sound, and by extension, all tube audio is automatically better than anything else.
I am aware tubes are hardly responsible for this as devices or as a technology, nor is it the fault of tubes that quite a few people buy something tubed and convince themselves that it's better sounding, because hey, it's tubes. My experience has it that in tube audio, more or less the same general rules apply as in SS - most products are just so-so, and there are some which are truly outstanding. True for both technologies.
I don't believe any technology is inherently better or worse than any other in terms of final effects, in this case audio. Some are more practical then others, some are more expensive than others, and so forth - but better by default? Never.
DVV
