Here's a few observations on tube V. SS.
Tubes:
1. If configured properly, introduce a lower order distortion spectrum which adds 'warmth' and 'grace', largely because of their transfer function and (normally) an absence of feedback.
2. Are arguably the best voltage amplifers in the science of electronics.
3. Operate at high voltage and low current, meaning high impedance, and thus have huge problems driving speakers of low impedance directly. They need transformers, and this complicates thing enormously.
4. Are electrostatic devices, and thus are highly susceptible to hum intrusion.
5. Interact hugely with their power supplies, making their proper use an art form.
6. Steadily burn out from the day they are switched on. This problem is very problematic with large bottles used for power stages.
7. Are staggeringly robust electrically, if not mechanically. The ruskies used them in all their military equipment because they resist EM burst from nuclear explosions.
8. Can be frighteningly expensive, cf. the WE 300B and 845.
Transistors:
1. Have huge current gain (beta) and thus must be operated with feedback, either local or global. Both are commonly used, with global feedback having many problems.
2. Are aguably the best current amplifiers in the business.
3. Have a different transfer function to tubes, which creates a very different distortion spectrum, depending on how they are configured, of course. Typically, SS is more accurate.
4. Display low impedance characteristics; emitter source impedance is typically given as 26 / emitter current (mA); thus a 1A device has an emitter source impedance measured in milliohms. Great for driving loudspeakers directly!
5. Are incredibly tough mechanically, if a little fragile electrically.......
6. Extremely inexpensive - a wonderful boon.
7. Microscopic in size, facilitating huge complexity in tiny space, viz integrated circuits, a marvel of modern life.
8. With feedback and certain other tricks, capable of stunning resolution, important particularly in complex, orchestral music.
There! Enough differences?
My own feeling is that the ideal audio amplifier, one designed for high resolution and vivid portrayal of musical color and emotion, is a hybrid, using tubes for voltage amplification, and SS devices, probably mosfets, for current amplification. I love 'em both........
Hugh
