BDP-1/2 Recommended Interfaces
0 Members and 3 Guests are viewing this topic. Read 287535 times.
Alpha10
Re: BDP-1/2 Recommended Interfaces
« Reply #380 on: 14 Sep 2013, 02:30 pm »
Hi Folks
There is a new version of MPAD available.
James
The full screen album art is good for me. Seems a bit faster as well.  :thumb:
Cheers
bjski
« Reply #381 on: 14 Sep 2013, 11:25 pm »
Hi Folks
James
bjski
« Reply #382 on: 14 Sep 2013, 11:41 pm »
James,
 Sorry about that. I have version 1.72 and I try to install the newest download and I get a failure notice. What to do? I tried this 8 times.
Rate:
Update Started - 2013/9/14-23:27:55
Downloading New Firmware (this may take awhile)- 2013/9/14-23:27:55
00%. 01%. 02%. 03%. 04%. 05%. 06%. 07%. 08%. 09%. 10%. 11%. 12%. 13%. 14%. 15%. 16%. 17%. 18%. 19%. 20%. 21%. 22%. 23%. 24%. 25%. 26%. 27%. 28%. 29%. 30%. 31%. 32%. 33%. 34%. 35%. 36%. 37%. 38%. 39%. 40%. 41%. 42%. 43%. 44%. 45%. 46%. 47%. 48%. 49%. 50%. 51%. 52%. 53%. 54%. 55%. 56%. 57%. 58%. 59%. 60%. 61%. 62%. 63%. 64%. 65%. 66%. 67%. 68%. 69%. 70%. 71%. 72%. 73%. 74%. 75%. 76%. 77%. 78%. 79%. 80%. 81%. 82%. 83%. 84%. 85%. 86%. 87%. 88%. 89%. 90%. 91%. 92%. 93%. 94%. 95%. 96%. 97%. 98%. 99%. 03%. 07%. 11%. 15%. 19%. 22%. 26%. 30%. 34%. 38%. 42%. 45%. 49%. 53%. 57%. 61%. 65%. 68%. 72%. 76%. 80%. 84%. 88%. 91%. 00%.
Checking Firmware Integrity - 2013/9/14-23:29:43
5b913ba6c2e5d138d35aefcba8f5078b /live/image/live/filesystem.new - 2013/9/14-23:30:7
Passed - 2013/9/14-23:30:7
ee50551364b884ea56a27ef4656bc4c1 /live/image/live/initrd1.new - 2013/9/14-23:30:8
Upgrade Failed:initrd, 2 - 2013/9/14-23:30:8
F
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #383 on: 15 Sep 2013, 01:18 am »
James,
Rate:
F
Will send to Chris for you.
james
bjski
« Reply #384 on: 15 Sep 2013, 01:28 pm »
Thanks James. :thumb:
bjski
« Reply #385 on: 15 Sep 2013, 05:07 pm »
james
James,
No need to forward the information to Chris. I reinstalled the factory settings and then just updated it until I had the current version.
BJ
« Reply #386 on: 15 Sep 2013, 05:19 pm »
James,
BJ
Great - will let him know.  :thumb:
James
« Reply #387 on: 5 Oct 2013, 02:58 pm »
Hi Folks,
There is a nice little interface available called  'reMPD'  from the Apple Store for the BDP for use on your iPhone or iTouch.  It is not as slick as MPOD but its a great backup and works well.  I am going to try it on my iPad Mini as well.
james
Alpha10
« Reply #388 on: 21 Oct 2013, 06:03 pm »
New version of MPad released, brought back bit rate display  :thumb:
Cheers
« Reply #389 on: 21 Oct 2013, 06:05 pm »
Cheers
THANKS :thumb:
Ned F. Kuehn
« Reply #390 on: 15 Nov 2013, 01:56 pm »
It seems as though bit depth/sample rate displayed over album artwork is now not working with iOS 7.04 or with my new iPad Air. Anyone else having this issue? By the way, the iPad Air really speeds up scrolling through albums with no hesitation on rapid scrolling.
dgb
« Reply #391 on: 15 Nov 2013, 07:21 pm »
I tried to use Minion with my Mac, but it doesn't work.
Maybe I'm using wrong setting.
Can I have an help ?
Thank's
dino
« Reply #392 on: 15 Nov 2013, 11:24 pm »
Thank's
dino
Hi
Minion is no longer supported by the designer and it was for Firefox only in Windows.
james
dgb
« Reply #393 on: 16 Nov 2013, 04:46 am »
Hi
james
Marius
« Reply #394 on: 16 Nov 2013, 09:55 am »
HI,
Don't know if its me, but on the Mac, i feel the only viable option is Bryston's own interface, or it had to be Theremin, which is really a bare bone, but very clean, interface.
Manic Moose is, though a work in progress yet, very very promising.
can't beat Mpod/MPad though. yet.
 my 2c.
Marius
Thank's
dino
dgb
« Reply #395 on: 16 Nov 2013, 10:29 am »
Hi Marius,
yes, you have my same opinion.
Before the bdp I used to run itunes on mac and jriver with win.
I'd not come back, but I'm not so satisfied about the bdp interfaces.
With Theremin a lot of albums, all aiff, are "unknown", with bryston max I don't have this problem, but I don't like it.
Maybe it would be a good idea go to ipad mini (for me a little bit too big) and run MPad.
What about Android, Nexus 7, for example?
Thank's, dino
Ned F. Kuehn
« Reply #396 on: 16 Nov 2013, 05:28 pm »
Depth/Sample rate back after a reset of MPaD.  :green:
« Reply #397 on: 20 Nov 2013, 06:06 pm »
Seems to work on Firefox 24 with BDP-2
dgb
« Reply #398 on: 21 Nov 2013, 01:31 pm »
Hi  James,
can you tell me, please, what I have put in the preference as : Description ..., Host ..., Port 6600, Password....
and then, what I have to write in the search bar to enter in minion ?
Thanks, dino
