BDP-1/2 Recommended Interfaces
0 Members and 2 Guests are viewing this topic. Read 286156 times.
dgb
Re: BDP-1/2 Recommended Interfaces
« Reply #400 on: 7 Dec 2013, 09:35 am »
Hi,
After one day working, I uninstalled MPaD, and I realoded it.
Now I can't find again the right way to configure the bdp-2 as server.
I'm using : CONNECTION
                 Connection mode     :  Remote
                 MPD
                 Server                     :  bryston
                 Port                         :  6600
                 Password                 :  bryston
                 Use LocalCache        :  yes
                 LOCAL COVER ART
                 URL                         : (nothing)
                 Cover File Name       :  Folder.jpg
                 Liner Notes Filename : (nothing)
Thank's in advance, I'm not absolutely expert.
dino
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #401 on: 7 Dec 2013, 11:17 am »
Do not use a Password
james
dgb
« Reply #402 on: 7 Dec 2013, 04:51 pm »
james
also without the Password it does not connect. I don't understand.
I tried to turn off both bdp-2 and ipad, to closed again MPaD and reload it, and then try again. no more connection.
« Reply #403 on: 7 Dec 2013, 05:38 pm »
Ok I see the problem
Leave the password off and the SERVER is NOT 'BRYSTON' - use the IP Address (prefered)  that is shown on the front display of the BDP or use     bryston-bdp-1.local
james
dgb
« Reply #404 on: 7 Dec 2013, 05:44 pm »
finally done with IPaddress instead "bryston".
but I think to have some problems, i.e. I find my files, some listed by their tags, other by their folder  name.
and also it does not show me the bitrate.
now I try with bryston-bdp-2.local
thanks, dino
« Reply #405 on: 7 Dec 2013, 06:00 pm »
thanks, dino
Hi
How MPAD reads the data will be a function of how it was implemented when transferred to the hard-drive (what program are you using?)
james
dgb
« Reply #406 on: 7 Dec 2013, 06:23 pm »
I ripped all my cds with EAC as flac with win, and then I used xld to obtain AIFF, because before the bdp I used itunes.
I tranfered my aiff files on the ssd inside the btp on the network, all in the same way.
some are listed by tag, some by folder (artist), some with the cover, some not, also if any foder there is the cover inside like Folder.jpg.
« Reply #407 on: 7 Dec 2013, 06:26 pm »
OK - I will ask others to respond as I use a PC and Flac files using DBPOWERAMP.
james
hal jones
« Reply #408 on: 8 Dec 2013, 03:38 am »
Seems to work on Firefox 24 with BDP-2
Is this on a Mac or Windows machine? No luck here on my Mac.
hal jones
« Reply #409 on: 8 Dec 2013, 03:51 am »
Found a work around for my issue... may help somebody else here....
from: http://code.google.com/p/musicpm/issues/detail?id=125
"As a workaround, it's possible to set the mpd server through the Firefox about:config page. Look for the value 'extensions.mpm.server'. If it does not exist, create a new one (right click -> string), with a value '192.168.1.2:6600:', where '192.168.1.2' is the ipadres of YOUR mpd server."
Ned F. Kuehn
« Reply #410 on: 8 Dec 2013, 04:50 pm »
james
I use PC and MediaMonkey Gold to rip or organize downloaded music files and tag files to FLAC. Control BDP-1 with MPaD. Use genre to identify HiRes files (192, 176.4, 96, 88.2, 48 kHz). I use DVD Audio Extractor to rip BlueRay audio (i.e, concert videos) to FLAC then import into MediaMonkey for tagging. By the way, MPaD is real quick on the new iPad Air.
gil99
« Reply #411 on: 20 Dec 2013, 01:06 pm »
Hi all,
Intend to buy an Ipad mini so would like to know if Mpod, Mpad or other available could be use to control the BDP-1 with the Ipad mini.  Thanks
Gil
« Reply #412 on: 20 Dec 2013, 03:21 pm »
Hi all,
Gil
Hi
Yes it can - I have one. :thumb:
james
gil99
« Reply #413 on: 20 Dec 2013, 04:02 pm »
Thanks James, which one works best with the mini.
Gil
« Reply #414 on: 20 Dec 2013, 04:56 pm »
Gil
They both work equally as well but I tend to use  MPOD as my old eyes can see it better :thumb:
james
dgb
« Reply #415 on: 26 Dec 2013, 05:40 am »
Depth/Sample rate back after a reset of MPaD.  :green:
I have the problem with MPaD and ipad mini retina, also after uninstalling and installing the app.
Maybe some advices.
Thanks, dino
« Reply #416 on: 10 Jan 2014, 08:03 am »
There is a new version of MPOD and MPAD is available from Apple store.
james
« Last Edit: 11 Jan 2014, 07:21 am by James Tanner »
Marius
« Reply #417 on: 11 Jan 2014, 03:42 pm »
Yes, and on the iphone i feel it is definitely a set back... :cry: too bad my updates download automatically in the background....
Can't you see the full album art, like before, with the resolution and format, either? Really miss that, and no feedback is shown anymore while updating the database.
Ive two BDP's showing: one as BDP, and one as bryston-bdp-1.local. Is that a new MPOD software issue, or something to do with the Bryston beta firmware i've installed? Please have a look in your situation.
Marius
james
Hear Clifford Brown
« Reply #418 on: 8 Feb 2014, 09:37 pm »
I did a little reading in here, but still somewhat confused so will just ask.  I'm thinking of buying a BDP-1 and want to control it with my Macbook.  What's best to use?  It seems MPad doesn't work on a Macbook, right?
Grit
  • - Garrett
« Reply #419 on: 9 Feb 2014, 07:36 am »
The BDP's can be controlled via any web browser. There is a "Max" and "Min" interface, as well as the settings. These interfaces are programmed within the BPD and do not require any additional software (save the aforementioned web browser).
