BDP-1/2 Recommended Interfaces
0 Members and 2 Guests are viewing this topic. Read 284516 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDP-1/2 Recommended Interfaces
« Reply #540 on: 30 Aug 2018, 04:47 pm »
SUBJECT: BDP Digital Player – Control Interfaces
September, 2018
Hi Folks,
There are now a large number of control interfaces available for the Bryston BDP Digital Players that we have tested and which work well.
1.   MANIC MOOSE – Preloaded Internal Bryston Software
2.   ROON
3.   RIGELIAN - Apple Store
4.   SOUNDIROK – Apple Store
5.   CHIMNEY – Windows Computers
6.   M.A.LP. – Android Play Store
7.   DROID MPD Client – Android Play Store
8.   Glider Music Player – Apple Store
« Last Edit: 30 Aug 2018, 06:17 pm by James Tanner »
Jozsef
« Reply #541 on: 6 Sep 2018, 04:26 am »
This list of interfaces was rather good timing for me so thank you for that, James. I originally hit a snag trying Rigelian with the BDP-2. The app insists on MDP V.0.19 while the BDP-2 seemed to like 0.17.6 and simply ignored my selection of 0.19.21 from the drop-down menu until I tried a different browser. It turns out that a slightly old Firefox version I still have for a specific feature will not work as intended with the current Manic Moose.
I mention this only because after solving the problem I was left with an undeletable and useless post so it seemed better to edit it into something potentially helpful. ;)
« Last Edit: 6 Sep 2018, 06:53 am by Jozsef »
« Reply #542 on: 6 Sep 2018, 10:47 am »
Thanks Jozef - glad things worked out OK.
We usually recommend Chrome with the BDP's.
james
« Reply #543 on: 9 Sep 2018, 01:55 pm »
New In Glider 2.0 for Bryston BDP Digital Players
• Generic MPD device support is now available, making Glider the only app on any platform to support all streaming protocols including: UPnP/DLNA, OpenHome, MPD, AirPlay and Chromecast. Many MPD devices will be auto-discovered, but a new option has been added to add an MPD device using the IP address and port number.
• A new 'Analog' display mode allows you to focus on album-based listening with a distraction free experience. Play full albums, one at a time with no extraneous features.
• Recently added albums are now displayed on the main Library screen, and the Albums view has a new 'Recently Added' sort option. Your history of recently added albums will be stored in iCloud and will be restored during a delete and re-install of the app.
• You can now easily add files to Glider using the iOS Files App, the 'Share' button in Safari, and AirDrop from your Mac.
• Last.fm integration has been added to automatically scrobble whatever's playing in Glider. If you're listening without an internet connection, then your scrobbles will be stored locally and synced to Last.fm when your connection returns.
Bug Fixes:
• Properly order tracks in the queue When playing multi-disc albums
• Allow local iTunes files to stream at the native resolution without downconverting
• Sync fixes for MyCloudEX2Ultra NAS drives
To test this app, open TestFlight on your iOS device using iOS 10.0 or later and install the update.
docder
« Reply #544 on: 10 Sep 2018, 10:22 am »
Thanks for the Glider 2 info, James - looks good. Is there a link to a Glider web page? Can't see one.
Are there beta testing opportunities available via TestFlight.
D
« Reply #545 on: 10 Sep 2018, 04:14 pm »
You can email Glider at:
[email protected]
alegar
« Reply #546 on: 14 Sep 2018, 01:59 pm »
Capture of the Glider application in its latest version, using the iPad for control and Bryston BDP-1 playing, I have to say that Glider is a very good application once migrated to the paid version, I control both the BDP and the Naz perfectly and I have access to thousands of music files with differen bitrate including DSD. I have to thank Mr. Joe Stelmach for his quick communication and his knowledge to start Glider on his iPad. I recommend you try Glider.
Greetings.
Alexander.
« Reply #547 on: 18 Apr 2020, 07:23 pm »
Hi Folks,
I’m happy to inform you that Rigelian is now also available as a Mac app from the Mac App Store.
So you can use this BDP control interface on your MAC laptop or computer as well as your Iphone and Ipad.
https://apps.apple.com/us/app/rigelian/id1363775934?mt=8
Johnney
Re: BDP-1 Recommended Interfaces
« Reply #548 on: 31 Jan 2021, 02:09 am »
You can also use the Bryston BR-2 Remote to control basic functions on the BDP-1 :thumb:
Play
Pause
Stop
Next
Previous
It works great when you load a playlist and can not be bothered with the visual interfaces. The Album and Artist are still displayed on the BDP-1's two line display as you move through the playlist.
james
Hi James, Can BR2 switch on/off of BDP-3?
« Reply #549 on: 31 Jan 2021, 11:29 am »
I believe so but I can check if you want - do you have a BR2?
The BR2 is no longer available so only the BR4 now.
james
Johnney
« Reply #550 on: 31 Jan 2021, 11:46 am »
james
Yes, please check it for me because it is main function for me to buy BR2. BR4 has similar function as BR2 besides outer case, backlight and auto sensing light? Thanks
KINS
  • What matter the most!
« Reply #551 on: 10 Aug 2021, 08:00 am »
Hi,
Just joined community, thanks to Adam TANNER from BRYSTON.
I am interested in Sound, that is what matter the most in an Hi-Fi system, don’t you agree?
Happy to discuss you experience with Digital Player in particular.
My best,
