0 Members and 1 Guest are viewing this topic. Read 17603 times.
I don't feel like you're diverting the thread. Your comments are central to the design concerns I have for this system. I need to add that offline information I got from Dave (planet10) and TerryO were very important to the box design. Danny from GR gave me the idea for the cap (which made a world of difference). They saved me weeks of tweaking.
I won't pretend to be an expert on this topic but I thing you guys should see what "Hebrew Hammer" has created. He has expanded on the idea that separate low frequency drivers is the way to go by bi-amping using a programmable electronic crossover. And the speaker itself is a work of art. You can see them on this thread: http://www.audiocircle.com/index.php?topic=88014.0or check out his website www.soundsbydesign.net I'm a nube but totally impressed. A couple of weeks ago I was lucky enough to hear these beauties. They completely disappear. Quite a feat in my book.Matt
IMHO, one ugly speaker, but there will always be wildy different opinions on art.dave
I agree. Butt-ugly and no hope for improvement. Like looking at the wrong side of a blond hippo up too close. At least they sound OK.
The blond hippo? Best Regards,TerryO
When was the last time you were in Walmart? ( )
or the sample testing line up at Costco? even with 10ft wide aisles between racking, it's often a tight squeeze to get by
there's no denying the work involved in the soundbydesign stuff, and Terry would certainly approve of the liberal use of MDF and bondo - although unfortunately covered with high quality paint job
"beauty" of course is in the mind of the beholder, and the fact that some of us remain married to the same / only spouse after over 30yrs, there's proof of least 2 other cliches
It's next summer for "Evil Annie" and henpecked TerryO. Best Regards,TerryO
Uhhh... Terry, your wife doesn't follow threads on this forum does she?
OK, back on thread.... (but it was so much fun getting off-topic!)Did the first really serious listening this evening. The sound is very smooth, detailed and transparent. I added in a couple of subs (note: not crossed-in, but added) running off of an old Marchand x-over used as a low-pass @ ~ 60Hz 4th order. Yeah, they will work just fine. Also, ran the FR125SRs a little too hard. They repaid the favor with some awful sounds. Not sure they bottomed-out, but they definitely modulated the highs and were very distorted. Yeah, the subs are going to help a LOT. Played mostly some really excellent vinyl a friend brought over as well as some of my own. Vocals, wind band (Mercury Fredrick Fennel), full orchestra, solo classical guitar and a couple of Rodrigo guitar concertos (Mercury The Romeros). Even some London Pinafore. Our shared conclusion was that the drivers were good enough to use in a system, and that they DEFINITELY needed a couple of subs crossed-in (take the lows off of the FRs). There is also a basic box design problem. We were both hearing imaging problems, particularly with percussion, at the extreme left and right edges when the instruments position was near the speaker. The instruments jumped to the cone of the driver. We thought it was likely the wide baffle.So....... (any comments on the following?)Away with those ugly boxes, now nicknamed the blond hippos. And on to the next test design. A narrow baffle, maybe 6" - 6 1/2" wide, beveled or rounded to just short of the width of the speaker. Speaker mounted as close to the top edge as reasonable. Bipole to help compensate for baffle step loss (adjust cap size across rear-firing driver until reaching the correct). 20 litres sealed (works good / smooth in the current box). Need to work out some kind of base to keep them from falling. A little time in front of SketchIt should do the trick.
Please Chris, I prefer the use-specific term: "Activated Polyester Tone Sauce". Bondo just sounds so......Walmart.
