0 Members and 1 Guest are viewing this topic. Read 17604 times.
We gonna see some fresh APTS at this year's diyFEST?
You would know. There is little warning and a very disturbibg fart when they hit the limits. Worst with SE amps (any siz, tube or SS).dave
Is that "Homeless" guy ( I prefer the term "Outdoorsman") still at large?
Still snow here too. Persistant stuff.Homeless guy?dave
He showed up last year wearing an Obama Bib, looking for handouts and free food. I personally don't have much patience for these "Dregs of Society!"
Eric, i guess. He is an important part of the community. And far from homeless. he has an acerage down the road with a bigger house than us.His job keeps him grimy -- he is the local recycle guy, taking away our scrap metal and helping to keep debris off the sides of the road. He can feed himself, he was more there for the company. Rarely does he get the opportunity to hang out with other music enthuisasts, and can get a little over excited.dave
Weren't think of any of you "up-island" pals were ya?"Outdoorsmen/campers"just askin,' free food's always a hook!Best, Don
From your description, they didn't bottom out. But there was considerable audible gnashing of teeth and heavily modulated highs. I guess the voice coil threw a bit out of the gap. I think it was on one of the tracks from the Freddie Fennel Screamers album (vinyl). We were playing the system a bit louder than I would normally run it. I was impressed with the dynamics and dynamic range up until that point. I was really satisfied with just how good the system sounded when the subs were added. Just need to try a box with a really narrow baffle to see how that works.
Yes, a dreadful lot they were too! I'm afraid I've been spoiled by the Opulent Splendor of Washington's logging towns.Don, are you going to be there again? I sure hope so, as I've got some new lies...uh, true stories to tell you! Best Regards,TerryO
Should I keep reporting in this thread and circle since this is not actually a single driver system (really a wide range with a sub)? Is there a different "circle" that I should use?
It just happens that I have more than a couple of amps laying around. I reconfigured the crossover so that the hp section separate from the lp section. I used four mono amps, one for each side hp and one for each side lp. I used a two-channel passive line level control in front of the lp amps. Pulled the lp level back a bit until the bass was at about the right level. Now that's what I'm talking about.Still need to tweak the lp crossover point a bit lower, but all the dynamic range is there for pretty much any classical music.
Hey Bill, I haven't stopped by as I thought you were still "vacationing" from the project. If you go with the bi-amping you might want to consider a higher order Lo-Pass while holding onto a first order High-pass. A line level crossover is pretty benign by comparison with a regular passive crossover. Asymmetrical slopes certainly work fine, although it might take a just bit more effort to integrate them, but it seems you're getting pretty close already. Come to think of it, you already know all that...I guess I must be talking to myself. Best Regards,Terry
I still need to design and build a better pair of cabinets. These are not too good and might be causing some response anomalies.
