0 Members and 1 Guest are viewing this topic. Read 53250 times.
YOURSELF keep on advertising a circuit with wrong input impedance..
Here I'm using my home SPDIF cable (2.3m)- real situation -, Hiface as driver, and the scope is in place of the DAC receiver input.
Count the nanoseconds, this is a 192kHz signal, the primary reflection is smack in the middle, but there is still life going on at 88nsec as well!
IFF you ignore the reality of high speed circuit design. Granted, many designers do indeed neglect this aspect. Digital links should NOT be alterable by an attenuator, but poor design prevents ideality..
Perhaps you should point out to the readers that placing an attenuator at the receiver attenuates both the signal and the noise.
Please explain how inductance in the feedback loop affects the roundtrip time of a reflection.
Please explain the physics underlying the above quote, jneutron.w
@ jneutronSo it's your intent only to disagree with minor points in my argument?
Otherwise respond to my post #161 ...main thrust onwards.
I have been responding to your posts where you fabricate statements and claim I've made them. Like your just asked question about how the fb inductance affects the rountrip time of a reflection.
With this in mind, consider what the output will look like if R2 is inductive.Where will that second spike be in relation to the initial waveform?Inquiring minds want to know...
And the fact is that it makes no difference whatsoever to the arrival time of the reflection.
I guess I'm talking about the arrival time at the input, and you're talking about the arrival (!) at the output.
But 'fabricate statements'... I think you are overegging the pudding.w
John,You have made numerous personal comments about me. For the large part my posts have been technical in nature.w
Wanna guess how close ANY transport or DAC is, to 75 ohms? Well, I can tell you.............There are TONS of products with a return loss in the 10 dB range. Which means the reflected signal is around 30% of the transmitted signal! Which also translates to an impedance of either (roughly) 39 ohms or 144 ohms. No so good, right?
Lower S/N? Yes. Less jitter created at the interface? Yes. Which is more important?
99% of S/PDIF outputs are not matched well to 75 ohms. 99% of all S/PDIF inputs are well-matched to 75 ohms. All this takes is a resistor usually.
Return loss is of little importance. This is not radio.
It is the reflection and the reflection timing that is important. It's the signal integrity at the receiver that's important. You know that..
Excellent question I wish there were DB tests showing exactly this. This is the problem I have with the guys at Audio Science Review forums. They say the measurements are the only truth and you cannot trust your ears, but at the same time, they cannot say whether it's more important to have low jitter, low HD, low noise floor or low crosstalk. The audiophile community needs this work to be done. Give each of these measurements a weighting based on actual human hearing.Only then can we maybe look at measurements and say with any certainty that one component will sound better than another.
BTW, do you believe that faster edges are the ticket to lower jitter? I won't tell you what I think yet.Steve N.
That is a ambiguous question. Jitter means different things to different people. When we talk of "jitter", we are strictly talking about clock jitter. And I am not going to discuss that subject. My patience is long gone, on that matter.
The problem is everyone wants their clock to sound like one that costs $100, but still only costs $1. Just because we are stupid enough to buy 1000 pieces of mystery parts, and take the time and spend the money to pick through them, to find the "diamonds in the rough"....................well, you would be surprised how much we end up paying for them.
The jitter that usually matters, jitter on S/PDIF or on I2S to the D/A. This is what I measure here:https://www.audiocircle.com/index.php?topic=157348.0and here are the measurement fanatics using a DAC for the same measurement (I prefer direct measurement for sources):https://www.audiocircle.com/index.php?topic=163027.0
I get this. The thing I focus on is not so much the oscillator, but all of the associated dividers, muxes, registers, selectors and buffers. These can take a 1psec phase-noise oscillator and make the S/PDIF output or I2S output have 800psec of jitter.
I have developed a bag of jitter tricks over the last 23 years that is very effective. I still get custom low-jitter oscillators that may cost $25, but I don't bother with oven-control or rubidium clocks because all of the other logic will usually add significantly to the jitter. I figure a factor of 5-10x the oscillator spec on the bench is what you actually end-up with on I2S, best-case and the power noise and ground noise factors in as well.
"BTW, all the crap added from muxes and dividers and other digital sources of crap have ZERO effect on what happens in the critical jitter range. Mind you, I am not saying it is not important or that you can not measure it or that it won't affect the sound. What I am saying is that the really important stuff (you know, down below 10 Hz) is unaffected by it."
This is precisely why crappy ol' SPDIF has any chance of sounding good. Even with a noise floor that is 30 dB higher than the source, eventually the phase noise of the recovered clock tracks the source clock. Which is why we can demo our gear with a ratty old DAC that was made almost 30 years ago, and you can hear a good clock from a really good clock.
A one time and one time only offer.Send me a few. I will measure them. Gratis. We usually charge close to 3 figures to do this, for other companies. The only caveat is that I can post the results here, and make sure the whole world sees them.
