Basic DIY Steam & Vac Record Cleaning Approach
0 Members and 1 Guest are viewing this topic. Read 23351 times.
orthobiz
Re: Basic DIY Steam & Vac Record Cleaning Approach
« Reply #40 on: 14 May 2011, 05:04 pm »
Thanks for the update, Davey. I usually have a record playing while the "on deck' record is soaking. But you're right, it's a time-consuming process.
Paul
etcarroll
« Reply #41 on: 9 Jul 2011, 10:20 pm »
Pumpkinman brought his steamer to my place last night, we went through a couple of albums I had run through the VPI 16.5, but still had pops.
My Beethoven 9th had at least a dozen pops in first 2 minutes, steamed it, now has one.
Steamed some others with surface noise, it's now 98% gone.
I'm sold on steaming.
What kind of steamers do folks swear by?
S Clark
« Reply #42 on: 9 Jul 2011, 10:48 pm »
I just picked up a Wagner wall paper steamer, but really haven't played with it much.  About $30 on ebay.  I need to find a good brush to use.  Any recommendations?
DaveyW
« Reply #43 on: 10 Jul 2011, 06:46 am »
Hi Gene,
Glad to hear that steaming has worked out for you too.
Re. Steamers - I am still very happy with the one I bought, has done at least 200 LP's now without a hitch.
This looks like the exact same unit I use for $25.
http://www.amazon.com/gp/aw/d/B000OP3ABM/ref=mp_s_a_12?qid=1310279669&sr=8-12
The right angle adapter that allows a cone of steam to be fired vertically downwards is a key feature.
Dave
DaveyW
« Reply #44 on: 10 Jul 2011, 06:57 am »
I know there are many different individual preferences for RCM brushes.
I did trial a few including Discwasher amongst others.
Where I got to on this is outlined in page 12 of my little guide HERE
vinyl_guy
« Reply #45 on: 13 Jul 2011, 02:42 pm »
I've tried the Mofi and Disc Doctor microfiber brushes as well as the Audio Intelligent brushes http://shop.audiointelligent.com/product.sc?productId=19&categoryId=2 I settled on the AI brushes. They are excellent for use with steaming (although a little on the expensive side).
etcarroll
« Reply #46 on: 13 Jul 2011, 05:52 pm »
Dave - nice guide, I'm printing it out.
Laura - at $30 that's not bad, Bill has me sold on the VPI brush at $40. I've been using the Nitty Gritty Nylon Bristle Brush, which is good for slightly to moderatly dirty records, but not stiff enough for the 'bad characters'.
DaveyW
« Reply #47 on: 14 Jul 2011, 11:55 am »
Thanks Gene,
In addition to the PDF guide, there's also some Videos HERE
Good Luck with your onward streaming exploits
Cheers
Dave
« Last Edit: 14 Jul 2011, 06:49 pm by DaveyW »
etcarroll
« Reply #48 on: 15 Jul 2011, 01:16 am »
UPS brought my steamer, now to put it to work with the vinyl behind it.
DaveyW
« Reply #49 on: 15 Jul 2011, 05:52 am »
 :thumb: Looking forward to hearing how you get on
« Reply #50 on: 15 Jul 2011, 08:35 pm »
Hurry Up Gene
