Just wait till the web site is up. The trumpeting and thundering from the driven herds of audiophiles will be astounding.Bud
When will it be up? URL?
o-netics.com This is our audio transformer company. The actual site will have a split personality, right out front for everyone to see. One side O-Netics and the other EnABL. The EnABL side will have links to licensee sites for diy drivers and finished in cabinet designs for EnABL'd drivers. Also will have pricing for the exotic drivers that I do, Lowthers and such and links to the argument and diy treatment sites. The Ground Plain, Ground Control, interconnect and speaker cables will also be under this banner. A shopping cart will be included and likely either forum or blog or both.You guys have just barely been introduced to the snake oil I have for you. Many pretty colors and exotic flavors available, in the rush to increase information retention in our hobby. The site is planned for mid January at the moment. Still providing art work & pics for a prelim design from Crystal Commerce. I figure if they can deal with the game card industry, and tens of thousands of sku numbers, I should be a piece of cake.Bud
Destroyer of Smiles, you can realize a substantial improvement in the size to the sound-stage, front to back depth layering and freedom from compression if you do not mount your circuit boards any closer than 1.5 inchs away from any portion of the metal chassis. The images of my power amp show one method of minimizing the circuit boards interaction with metal of the chassis. The image of my DIY buffer shows another way of maximizing the space between the circuit board and the top and bottom of the chassis. This is a good way of maximizing the performance of your amp or preamp if your circuit boards are not designed as described by Bud with an instrumentation type ground plane.Scotty
Looks like your PCB's are using the ground buss properly for power, for an instrumentation ground. Assuming that the orange layer is on top of the board and we are looking at the component mounting side. However, I do not see any hint of a ground plane in what I take to be the central signal section.Bud
