Hi I've been following this thread for some time with great interest but no success what so ever. I've experimented with 2 different systems one with Planet Ten Half Changs using the Fe207 drivers fully tricked out by Dave including EnAble and a Class D Audio SDS-4 kit amp. The other has Sonic Frontiers Monoblocks and Sonus Faber Cremonas :I have tried the following DIY ground loops:2' lamp cord exactly as was initially recommended2' Radio Shack 16 G stranded the above RS wire cut down in 2" increments to 1' loops2' of 12G wire with heavy dielectric20 " of 20g solid core hook up wire using both 1 and 2 strandsIn all cases the soundstage collapses to varying degrees and the highs become rolled off with a slightly muddy sound overall. These effects were more pronounced with the single driver speaker set up. Either I'm not hitting on a good combination or this is one tweak that just does not work for me.I've left a couple sets in for a good 8 hours to see if it was a burn in phenomenon without any change in the presentation.Ideas and comments are welcomeThanks Kevin
stvnhar,What equipment does your stereo system have in it. Also what loudspeakers are you using in your system. It would be very helpful to know what combinations produce null results.Scotty
stvnharr,You are in the sweet spot! The only place you might get some benefit from is upstream commercial CD player or out board DAC. You are exactly correct in thinking that you have solved the same problem that Ground Control solves, sonically. Cheers to you, you are one of the few who have gotten it right.Having said that you might just want to try out a Standard GC RCA upstream if there are strip grounds there.Bud
Are the speakers also DIY,if so pictures of them would be cool!Scotty
