0 Members and 1 Guest are viewing this topic. Read 72622 times.
SYSTEM USED FOR EVALUATION: Speakers: OB Audio Nirvana 15 full range driversDigital: Virtue Audio Piano1 CD playerPreamp: Niteshade Beacon 2 and custom build preamp used for comparisonAmp: Decware SV83M SET Monoblock tube amplifiersAC management: Majik BussLucky likes it NITESHADE BEACON 2 PREAMP GALLERY - CLICK HERESetup in medium size room on the short wall (that arrangement sounded best).Window behind speakers was partially covered with GIK treatments.Material used for evaluation varied from Jazz, vocals, small band, demo CDs from Usher, Chesky, NYAR etc.
Keep good communications between yourselves and don't hang on to it for over 1.5 weeks- so we can keep things moving smoothly. Everything is going pretty good so far! NOTE: If you're watching the tour and would like to jump in on it or if I forgot to place you in the list, just let me know. Thanks everybody!
I'll be out of town the end of Sept, starting the 25th through 10/1.
HeyTours never go according to plan. And It might be possible to improve Beacon Two but....... is it a worthy proposition????$100 just for the new Beacon Three logo. $150 for premium caps or $250 for "SOTA" caps. $150 for all wood enclose. So, do you think it is your lucky day?Do you????
