0 Members and 1 Guest are viewing this topic. Read 72621 times.
So, are you keeping it?
Hi,How does Beacon 2 compare with your custom preamp ?
Hello all-The Beacon Two uses a Single Ended Parallel (SEP) tube configuration. Both triodes are combined to make one large triode. The result is a high performance circuit that uses very few parts. I won't get into too many specifics. It is a well thought out design and performs the way it does because there are so few components. I've always been one of those people to look at something made with 100 components and say, "That can possibly be improved upon and at the same time be made with 25 components". Remember, fewer components dramatically improves longevity by decreasing the probability of failure. A nice perk!
(Beacon is great, just add Eggs and Coffee)Mariusz
A word about frequency response: This preamp was designed to be flat from 20-20,000hz. No part of the spectrum is accented or attenuated.
Forgot something: The power supply does not use a choke. It uses resistor coupling. A choke is not necessary with this design nor would it improve anything- that is why I do not offer it as an upgrade.
What kind of upgrades would the audience and reviewers like to see? Keep in mind the price point when adding bells & whistles. The standard configuration uses all high quality components that would be difficult to upgrade or to justify the cost of doing so. Regardless, suggestions are welcome. In fact, many cosmetic upgrades were due to the opinions of AC members!
Thank You Blair for including me on this tour. Looking forward to it. Ritchie
You can always tell us what brand of eggs and coffee you like....especially since several million eggs at the moment are on a recall... AC'ers want to get ultimate enjoyment out of their Beacons...Anand.
I also noticed your understandable inquiry about upgrade possibilities. It certainly is a valid point. Circuit is so simple with very few component parts that it should be (IMO) fairly easy to experiment and hear various parts swap influence the sound. But that's something to think about for those more advance tweakers. Regular guy who is looking for plug&play solution doesn't have to worry about it,......because it will make him smile as soon as it is taken out of the box.
Guys-- I'm leaving on the 10th-- so if it does not work out,thats how it goes,, no worries,, I'll be back on the 20th--thanks
