0 Members and 1 Guest are viewing this topic. Read 9374 times.
John,you have the VPI Classic as your main spinner,?? right ? can you tell what 3 carts your ears like the best as i find that kinda info really good for all. Woodsyi,you bring up a point i too really wonder about,will diggie keep getting better ?? if the last while's improvements keep going,where will we be in 5 years ???? every 16 months diggie tech doubles,soooo how good will those 0's-1's sound.... also,are speakers being left behind,seems they are stuck in the mud,unless you have crazy cash....
For me it is not about the equipment or the formats, it's about the content. Having both digital and vinyl gives me choices of content that I would never have if I stuck to just one or the other.--Jerome
Yeah neo, I'm sure there are much better DAC's than that little Chinese unit, but it's certainly the best bang for the buck I've yet encountered. Apparently you can rip it open and mod up the analog stage and put a better power supply than the wall wart on it and significantly improve the sound, but I've been happy with stock so far. For others reading the thread, it's the Beresford unit without the Beresford name or markup.
Got a link on that overperforming/underpriced DAC, Letitroll? I'm pretty smitten with what I have here....but I'm a sucka' for well priced gear that sounds great. John
John: Fluid damping???????? Please help this dumdum and explain it to me. Cheers Charlie
John: Looks like my Rega P3-24 doesn't require fluid dampning. I'm trying to get back into a decent LP playback system. The Rega I have is not the answer. It's just okay. I tried a Grado Platinum 1 for a while and it had a better sound but still not to my liking. I'll keep trying. Maybe I'll get a good combination together someday that sounds good to me. Cheers Charlie
