0 Members and 1 Guest are viewing this topic. Read 36638 times.
External Power Supply:Some consideration should be given to the external 9V to 12V power supply. Yes the switched mode power supplies that come with most modern appliances WILL PROBABLY DO - you know the light ones. But it is better to use a better quality PS i.e. probably one with a transformer in it (i.e heavier). Remember, this is the feed for the 5V & 3.3V regulators in the MK2 modified Hiface box so the cleanest possible power is advisable.
A suitable UK 9V DC supply is £14 here but others may well be available locally in your area.
A suitable US 9V DC supply is $10 here but again others may well be available locally in your area.
What you want is (v to 12V DC supply of 500mA or greater output with a 2.1mm plug with positive centre contact.You could also run this off a 12V battery using an adapter plug like this or this, again respecting centre pin is positive polarity.
