0 Members and 1 Guest are viewing this topic. Read 33939 times.
Component matching is tricky with passives. The best success I've found is in using attenuators plugged directly into my monoblock power amps (which eliminates interconnect worries). If the source output exceeds the power amplifier rated input sensitivity you should be all set with a passive.
The Nelson Pass B1 buffer is a passive, zero gain device designed primarily to assist with impedance matching.
Good point JLM. IC capacitance becomes quite a factor, so it is important to check, or even eliminate the IC altogether with only the component input capacitance to consider.(Caveat: I do manufacturer active preamplifiers.)Cheers.
Does anyone know the advantages and disadvantages of using these two type of preamp? How would they differen sonically?
For resistor based passives absolutely yes. For transformer based no. One can use up to 5 mtrs. However I would recco a cable with low cap. charles
Unfortunately, there is no free lunch. In addition to the volume pot and the buffer stage, B1 requires a 1 uF and 10 uF capacitor in the signal path, which is not so trivial to get half-way decently transparent..
Compared to my average-ish SS preamp, I'll take the passive every time. Although it has a bit less output than my active preamp, it has plenty of gain to play very loud, and the sound is much more refined with a bigger soundstage and more air and space around the instruments.
Hi Charles,I respectfully disagree as the capacitance of both input and output ICs is across the primary and secondary of transformer based units. As such resonances occur, but minimized with proper precautions. The higher the capacitance the lower the resonant frequency.I have a general article discussing the subjecthttp://www.sasaudiolabs.com/theory11a.htmCheers.
Very interesting Steve. Thanks. charles
The technical arguments mentioned after this post are interesting and valid, however, "how does it sound?" is the most critical. Passive preamps will generally be less dynamic than active stages, but as roymail notes much more pure and refined in character. And as he notes if you have the gain for it in your source components and either the power to drive your speakers or efficient speakers, or both, passive preamps are preferred.
