0 Members and 1 Guest are viewing this topic. Read 33941 times.
This is pretty close:
The perception of less dynamics with a passive was not the case with my setup.
I have found that most actives exaggerate dynamics. Most people like this kind of presentation. With the sorry state of most recorded music, with limited dynamics, this is completely understandable.
A passive preamplifier actually is not a preamplifier at all, inasmuch as it does not amplify.
I prefer the term passive attenuator or passive volume control. I think the term passive preamplifier simply means that the passive device is after the source and before the amplifier, hence, pre-amplifier.Reviewing all the posts in the thread indicates to me that most have a pretty good understanding of the differences between active and passive volume controls along with their advantages and disadvantages.
Another problem one encounters is that the preamplifier active circuitry can usually be designed much better than either the circuitry in the amplifier or the analog stages in the DAC/CD player.
But if one wants the most accurate/musical sound, then I would suggest going with a superior active preamplifier and eliminate the poor analog stage in the DAC/CD player if possible. And if possible go for a basic amplifier and eliminate the first stage in an integrated amplifier. That way one eliminates two stages of amplification, the DAC/CD analog stage, and the first stage in an integrated amplifier, producing better overall fidelity when matched.
QuoteAnother problem one encounters is that the preamplifier active circuitry can usually be designed much better than either the circuitry in the amplifier or the analog stages in the DAC/CD player. Why would this be so?
QuoteBut if one wants the most accurate/musical sound, then I would suggest going with a superior active preamplifier and eliminate the poor analog stage in the DAC/CD player if possible. And if possible go for a basic amplifier and eliminate the first stage in an integrated amplifier. That way one eliminates two stages of amplification, the DAC/CD analog stage, and the first stage in an integrated amplifier, producing better overall fidelity when matched. I would think you'd want to improve the output stage of the DAC/CD player so that it can drive the patch cords, wiring, volume pot, etc. in the preamp properly. Then you have a good line stage, and finally a good amp. (Or you could just use a good integrated amp, but you'd still want a good output stage in your DAC/CD player.)
Does anyone know the advantages and disadvantages of using these two type of preamp? How would they differen sonically?Thanks
One then performs sophisticated long term special listening tests to determine the transparency (say of the preamplifier) in absolute terms and make adjustments. Virtually no one does all this because it is so difficult, although superior.
A little off topic, sorry, but refreshing to be on a site where the engineers use listening as the final judge. I could care less if my preamp is passive or active, I want the purest, most neutral presentation.
Steve you are correct, the actual pre is a part of the digital player I use. I had previously used DAC, tubed pre etc, but went with a simple, single source system.
It is absolutely critical that the analog gain stages be as transparent as possible. Any CD, DVD, or Blu-Ray player, not costing many thousands of $, is going to have a less that stellar analog output that will just pollute the signal throughout the signal chain from then on. I attribute the dissatisfaction of digital formats to this cause. A DAC that addresses the analog signal handling well, isolation from the digital supply, ground plane management, low output impedance, and high gain, will deliver superior performance from any digital source, and will deliver a clean signal to the subsequent gain stages from then on. This is especially important when going passive.
