13 amps circuit
0 Members and 1 Guest are viewing this topic. Read 5464 times.
Deftone
13 amps circuit
« on: 30 May 2010, 03:56 am »
hello all,i am new to this forum and also a newbie in the hifi world.Just want to know if its ok to run the system that i an trying to get thru a 13amps circuit or do i need a 15amps/20amps electrical circuit?Your reply is much appreciates.Thank you.
Napalm
Re: 13 amps circuit
« Reply #1 on: 30 May 2010, 04:02 am »
What is the system comprised of?
Nap.
Deftone
Re: 13 amps circuit
« Reply #2 on: 30 May 2010, 04:20 am »
Nap.
Nap,I will be getting the 4BSST2,BP26,BCD-1 and the BDA-1.Will add the 6BSST2 and the SP2 or the SP3 later on.
Elizabeth
Re: 13 amps circuit
« Reply #3 on: 30 May 2010, 04:22 am »
Add up the wattage of each of your components: then if it is less than 1,300 watts your OK.
My Bryston 4B-SST2 andBP-26, BP1.5, several digital components, and two powerline conditioners, uses an average of 600 watts. (this is the utility bill calculation with stereo on, but not always playing 24/7.
So 600 watts is well within a 13 amp circuit, and I have a LOT of stuff turned on and connected.
BrysTony
Re: 13 amps circuit
« Reply #4 on: 30 May 2010, 04:51 am »
Total available watts from a 13 amp circuit is typically a little more.  If you have 120 volts on the circuit then watts available would be 13amps X 120volts = 1560 watts.
Tony
Napalm
Re: 13 amps circuit
« Reply #5 on: 30 May 2010, 04:56 am »
I'd say that if you don't go ape on the volume it should work.
I would calculate it as sum of idle power consumption of all components + 200 Watts musical power.
Nap.  :thumb:
Deftone
Re: 13 amps circuit
« Reply #6 on: 30 May 2010, 05:10 am »
Tony
Tony,what i am having now is 220v with a 13 amps circuit.
Nap,i am not going to blow my roof off. I only listen at a comfortable volume level.
Napalm
Re: 13 amps circuit
« Reply #7 on: 30 May 2010, 05:13 am »
Sounds like you're in Europe. At 220V/13A it should work no matter what you do, blowing the roof included. Just connect them and enjoy.
Nap.
BrysTony
Re: 13 amps circuit
« Reply #8 on: 30 May 2010, 05:18 am »
Nap.
I agree -- the 220V gives you more available watts: 220 X 13 = 2860 watts.  Crank up the volume!
Tony
Deftone
Re: 13 amps circuit
« Reply #9 on: 30 May 2010, 05:36 am »
Nap.
Nap,not Europe but from the far east,Singapore exactly.
larevoj
Re: 13 amps circuit
« Reply #10 on: 30 May 2010, 05:48 am »
Deftone, I have similar configuration as yours and I too is located in Singapore.
Not a concern at all...pump it up buddy.
JL
Deftone
Re: 13 amps circuit
« Reply #11 on: 30 May 2010, 05:56 am »
JL
Hi JL,nice to meet you.Do you run all your component with a dedicated 13amp outlet or you plug all into a power conditioner?Been looking at the Torus the other day ,pretty interesting.
larevoj
Re: 13 amps circuit
« Reply #12 on: 30 May 2010, 06:06 am »
Given a choice it would be ideal to power your amplifier with a dedicated 13amp outlet. I run all my electronics through the PS Audio Quintet Power Center. The Torus IS a very good option you can consider  :thumb:
JL
Deftone
Re: 13 amps circuit
« Reply #13 on: 12 Dec 2010, 03:26 am »
JL
Are you using the U.S. or U.K version?
larevoj
Re: 13 amps circuit
« Reply #14 on: 12 Dec 2010, 10:25 am »
I haven't got my Torus yet but is seriously considering the UK version...  :)
Deftone
Re: 13 amps circuit
« Reply #15 on: 12 Dec 2010, 11:27 am »
What about your Quintet,U.S or U.K?.Do you get the ps audio power cable or a different one?
larevoj
Re: 13 amps circuit
« Reply #16 on: 12 Dec 2010, 11:36 am »
I use the UK version.
Some prefer the US version as there is no fuse or ground to worry about in the power line.
whanafi
Re: 13 amps circuit
« Reply #17 on: 14 Dec 2010, 05:40 pm »
Three of us in Singapore...
I have had problems in older flats.  The original spec for what was the Power Board in the 80's was for 48amp service to a flat - with aircons, an iron and the oven going, my Bryston would kick things over the edge.
Now when I go looking for a flat, I make a beeline for the breaker panel - if there isn't enough capacity, it doesn't matter how good the view is.
Deftone
Re: 13 amps circuit
« Reply #18 on: 14 Dec 2010, 06:47 pm »
Yeah nice to meet you.I don't know about now, it could be 40-60 amperage per household.Even then I am getting my electrician to do a 16a or 20a dedicated line for the hifi need.and also rearranged the wiring in my db coz its a total messed with what the last electrian did.Also I am in a dilemma should I install the u.S or the u.k receptacle and plugs.
larevoj
Re: 13 amps circuit
« Reply #19 on: 15 Dec 2010, 01:37 am »
My was a after thought which is why I am considering the Torus. You think the Torus would make any diff if your have a dedicated power line to the system?
