0 Members and 1 Guest are viewing this topic. Read 28460 times.
...not sure I'm seeing the upgrade I had hoped to. I'm using the Squeezebox into my Eastern Electric Sabre32 DAC and while it was pretty resolving and sounds great for what it is, it is clearly inferior as a transport to my Philips 963SA. In comparing the two the philips is a richer, more developed sound that is just as fast and a lot more engaging. Its more resolving with the DAC than I remember the Duet being, but the balance and sound seems to have change... Is anyone else not sold on the Touch as a transport? Is it possible I got a dud?
If you are using the Touch as a digital transport only, does the PS make a difference? Seems like it shouldn't.If so, on how does it effect the digital stream?
Where does the signal actually come from? The power supply. The power supply affects everything. What are the "1s and zeros"? )0V and 3.3 V. EVERYTHING in audio is dependent on the power supply.
Uh that would be your DAC buddy. Between the SB3 and the Touch, the Touch as a transport is far superior. The clarity & detail are excellent. Using the same DAC the BDA-1, you can instantly hear the difference between the two. Also use a linear power supply for the best signal.M
Your power supply will require 2-3 weeks constant use to break-in. About the same amount is required for the Touch to sound it's best.I am using a Touch with a bit better power supply than you have into an EE DAC. It is by far the best digital I have had in my system. Give everything some time.
TJHUB,Yours is not an unusual finding at all. While even a glass toslink does not offer the pulse fidelity of a properly implemented coax connection, it does offer the tremendous benefit of electrical isolation between transport and dac. If your transport is coupling internal noise to its coax spdif output, it interferes with the operation of spdif input circuitry. If you have properly implemented spdif coupling transformer either or your transport or dac (or both), which provided galvanic isolation between the two, you'll generally find the coax spdif preferable.GBB (Gary) discussed this a long time ago -http://www.audiocircle.com/index.php?topic=24353.msg217382;topicseen#msg217382Regards,Paul
TJHUB- thanks for posting, I thought I was alone in the choice of using toslink with my Duet, glad to hear someone else is experiencing the same thing I am.
I love it...now I'm thinking OK , I'll find a better toslink cable as opposed to my $3 ones from Amaz.. so I'm looking for specifically glass designation in the product description?? after a quick look at parts exp..they are typically $30 ish? On a fixed income here so I can't go nuts or I would believe me!!! Anyone have a link to a known good one thats not gonna cost a ton??Not trying to hijack the thread-just a side bar as it were...
