0 Members and 1 Guest are viewing this topic. Read 28425 times.
mchuckp, I see that you are using both the Oppo BDP-SE and Touch as a transport. Can you compare how they sound as transports through your W4S DAC? Doubt I am alone having all three of these pieces of equipment on my radar...
Gopher, this is day 3 for the Touch and the PE supply. I measured the supply before I started using it. 6.00 vdc...and all the other selections were spot on as well. I tried all of the dc connectors from PE, only one would fit, and its very snug, I also checked this, and this may be your problem, polarity on the DC, make sure you dont have it reversed, if it is the Touch will NOT power up. I cant not hear any real differences in tone, timbre, bass, highs, but do when i switch back to the stock supply.Its really sounding GREAT!! and the supply is not running hot at all.All the bestAlex
Care to share?
Tonight I dug out a brand new toslink cable I bought some time ago from BlueJeans that never got used. I did some comparisons back and forth to the coaxial connection (also BlueJeans) into my Wyred4Sound DAC-1. At first, I thought the Toslink WAS sounding better than the coaxial but after further listening, I felt the Toslink was a bit harsh in the presentation. It did seem to be pulling more out of the recording but didn't seem very smooth to me and a bit harsh on the ears. The coaxial seemed a smidge less detailed but had a very nice smooth sound to it through the whole frequency range. So for me, I guess the question is it more of a matter of preference in presentation or maybe my Toslink path needs broken in my DAC as this is the first time I have used that path. I'm gonna keep streaming some data through the Toslink for a few days and do a comparo again. I did notice my DAC-1 really smoothing out nicely as it got broken in. Not sure if one needs to break in each path individually.Also, based on TJHUB's suggestion, I ordered a glass fiber toslink from Parts Express. I'm VERY tempted to order a Bolder power supply to see the effect.
Wanted to throw out an update. I noted above that I preferred the coaxial over optical into my W4S DAC-1 from the Touch. It was recommended I try a glass toslink. I ordered the one recommended from Parts Express and gave it a whirl. I found the bass slightly better using the glass over the plastic fiber, but still preferred the sound of the coaxial. Not denying the findings of anyone else in their preference but in my system, it just isn't cutting it. Optical just comes off a little harsh and just sounds "Off". Coaxial is a very smooth presentation to my ears and preferred.Again, not denying what others notice. I think it just shows that you need to check out the options given to you and decide for yourself. Every system is different and everyone's ears are different.
Sorry the glass optical didn't work out for you. Because of this post, I just did another comparison of my glass optical cable against my digital coax cable this morning just to make sure I still felt the same.For me, the digital coax sounds good, but the glass optical sounds more open and clear. I can hear more ambiance in the music (a lot more actually). The imaging is much more precise and separation is greater. The glass optical is just overall cleaner sounding and neither the coax or the glass optical is harsh or grainy sounding over the other. I don't know what it is with my gear; the Duet, my DAC, or whatever. All I know is that the glass optical cable is the clear (pun intended) winner for me.
...the digital coax sounds good, but the glass optical sounds more open and clear. I can hear more ambiance in the music (a lot more actually). The imaging is much more precise and separation is greater. The glass optical is just overall cleaner sounding and neither the coax or the glass optical is harsh or grainy sounding over the other...
"Personally I find it unfortunate that S/PDIF was ever specified to run over coax copper in the first place. There are some who claim it's better than fiber for various reasons, but all empirical data says that optical S/PDIF is FAR more reliable, works over longer distances, and delivers measurably lower jitter at the receiver. It also inherently isolates ground offset, low frequency and EMI noise between devices. The only good reason to use coax is if you don't have an optical cable or an optical input available, which is primarily why we have the connector there."
Same here - your description is (more or less) what I have generally found as well. On the SlimDevices/Logitech forum, the original SlimDevices designer (Sean Adams) once advised the following, which may explain why some do hear such differences between optical vs. coax digital:
I know that for me using optical just sounds better all the way around for my setup, not sure why, it just does. I use Optical out on my PS3 to a DAC and its awesome, I use Optical out on my Blu-Ray player most of the time as it sounds better to me that way-its a 5.1 setup. Optical out from my Squeezebox just sounds fuller, more detailed..I did blind A,B tests with my apartment buddy and always preferred the sound from the Optical outs over the coax everytime....FWIW
