New patent pending product
0 Members and 1 Guest are viewing this topic. Read 18800 times.
jtwrace
    • TIPP YouTube Channel
Re: New patent pending product
« Reply #40 on: 18 May 2010, 01:17 pm »
My good friends at Electra Cable said that it is not only been filed it has also been given an application number. US 61/343,708.
Cool.  Can't find it in the db though...maybe it hasn't been entered.  I'll keep checking!   :thumb:
sts9fan
« Reply #41 on: 18 May 2010, 01:17 pm »
that's a provisional application
i.e. not public
we will have to wait
jtwrace
« Reply #42 on: 18 May 2010, 01:18 pm »
i.e. not public
 :cry:
Danny Richie
« Reply #43 on: 24 May 2010, 03:02 pm »
I still have some of these from the bag of blems bag that I bought. So if you want to try a set of these for only $25 a set then now is your chance to get some.
Mariusz
« Reply #44 on: 24 May 2010, 05:31 pm »
Just gotem in mail.
P.S
quick question (which might be somewhat difficult to answer)
Q:
Studs are pretty tight fit and that's good news however, removing them takes a little effort because of its size and nature of the material.
So, my question is - do you plan on offering sone kind of shell/plug/grip?
Or, do you have any other (grip) suggestions for DIY crowd?
Mariusz
ebag4
« Reply #45 on: 24 May 2010, 05:35 pm »
I just recieved mine as well, thanks Danny.  Question, can you purchase replacement studs for the speaker cable side?  I don't want to crimp these on a wire that I may change out in the not too distant future.
Ed
Mariusz
« Reply #46 on: 24 May 2010, 05:49 pm »
Ed
I was just looking at the stud construction and there is a potential for more user friendly wire hook-up. It might be possible to implement tinny screw (hold down) in the mid part of the stud. That is the thickest part of the stud and it might be enough to get enough thread to secure the wire with the small screw.
Something similar to Audioquest's solution.
Just a thought
ebag4
« Reply #47 on: 24 May 2010, 05:52 pm »
Thanks Mariusz.  I was just looking at the diagrams on the website, they call for a bit of solder just behind the collar of each connection, I am thinking I may just use that and some heatshrink temporarily until I decide on a cable.
Best,
Ed
Mariusz
« Reply #48 on: 24 May 2010, 05:59 pm »
It is just an idea for Denny to think about.
It would be quite difficult for regular "Joe" like myself to do tho.
But it sure would have been appreciated it.  :eyebrows:
(Ill use solder as well)
ebag4
« Reply #49 on: 26 May 2010, 01:49 am »
Danny,
I just installed the first set of the new binding post in my V-1s,WOW, why didn't someone think of this sooner, it couldn't have been easier!  The fit is so tight ith the 7/16's hole I dont see any reason to use glue at this point.  Of course if they were to ever get loose I could add glue but it took some decent effort to get them in flush.
Best,
Ed
jtwrace
« Reply #50 on: 26 May 2010, 12:00 pm »
Danny,
Best,
Ed
Installed Pics?
ebag4
« Reply #51 on: 26 May 2010, 12:30 pm »
Installed Pics?
Soon my son, very soon :lol:.
I will post pics hopefully tonight when I believe I will have them running.  I will post a few progress pics as well.
Best,
Ed
ebag4
« Reply #52 on: 26 May 2010, 02:21 pm »
Installed Pics?
Here are a few (really bad) pics of the binding post installation.  Very simple and quick.
I inserted the speaker wire pin to determine how far to strip the wire for the binding post.
Wire stripped
Binding post on wire
Binding post crimped
Binding post soldered
Binding post pressed into speaker (very tight fit in 7/16s hole)
Quick and easy.
Best,
Ed
jtwrace
« Reply #53 on: 26 May 2010, 02:24 pm »
Cool.   :thumb:
Look forward to your impressions on the speakers
Danny Richie
« Reply #54 on: 17 Jun 2010, 02:49 pm »
Looks like one speaker manufacturer is already on board. Custom units are being made in Black and Gray for them.
For any and all of you guys building new speaker projects, these are a must have.
satfrat
« Reply #55 on: 17 Jun 2010, 03:56 pm »
A little shrink wrap over the soldering would be a nice touch,,, just a thought.  :D
Robin
ebag4
« Reply #56 on: 17 Jun 2010, 04:05 pm »
Robin
A little too late for that Robin, they are crimped, soldered and installed  :wink:.  You could shrinkwrap over the solder but not over the barrel of the connector, not if you drilled a 7/16"ths hole. very tight fit without the shrink wrap.
I'll try to do better next time  :oops: :wink:.
Best,
Ed
satfrat
« Reply #57 on: 17 Jun 2010, 04:15 pm »
A little too late for that Robin, they are crimped, soldered and installed  ;) .  You could shrinkwrap over the solder but not over the barrel of the connector, not if you drilled a 7/16"ths hole. very tight fit without the shrink wrap.
I'll try to do better next time  :oops: ;) .
Best,
Ed
I hope I wasn't coming across as complaining Ed.  :oops:  It was just a thought that might or might not be a good idea for others. The pictures are a great touch as they've always been Ed.  :thumb:
Robin
jtwrace
ebag4
« Reply #59 on: 17 Jun 2010, 04:18 pm »
Robin
No worries Robin, just a little ribbing which doesn't always come across correctly when written.
Best,
Ed
