Next Gen iPhone?
0 Members and 1 Guest are viewing this topic. Read 9490 times.
Doublej
Re: Next Gen iPhone?
« Reply #60 on: 3 Jul 2010, 01:32 pm »
Assuming you have coverage, the reception isn't an issue.  The upper left quadrant of the integral antenna can be interfered with if you hold it there.  That is the one weak point of the system.
There is a device that works wonders for all AT&T 3G phones.  If your house is between cell towers, there is a microcell (looks like a modem)  that will give you 5 bars.  AFAIK, verizon doesn't have such a device, so if you are out of range at home, you are out of luck.
And BTW:  the Iphones virtual keyboard is easier to use than my LG qwerty keyboard, which is like a blackberry keyboard.
Look and ye shall find...
http://www.verizonwireless.com/b2c/store/accessory?action=gotoFemtocell
But who cares anyway. Phones are passe.
« Last Edit: 3 Jul 2010, 02:55 pm by Doublej »
Construct
« Reply #61 on: 4 Jul 2010, 12:57 am »
Cool.
"Print is dead"- Egan/Ghostbusters 1984
