0 Members and 1 Guest are viewing this topic. Read 7173 times.
I have been following this forum for a while now and have had an email exchange or two or three with John Casler about VMPS products. A pair of RM30M's was listed for sale on Audiogon and since it was local I had the opportunity to check them out in person. The interesting angle is that these speakers had never been set up, essentially a new pair. The backstory is on Audiogon for the curious.
These speakers in piano gloss black are visual stunners. I did some preliminary listening and knowing they had not been broken in heard their potential. I got them home without incident and set them up in my dedicated listening room (12.5 x 15 x 9, floor to ceiling bass traps in corners, two 2x4 OC703 absorptive panels per wall surface, carpeted floor). The equipment room is a door-less walk in closet adjacent to the speakers. My first impression on power up with music was that I had just made an expensive mistake. But I also recalled the glowing reviews and awards the VMPS product line has garnered, and the positive comments here. So I figured they needed some break-in time, positioning and tweaking.
Initially the woofers were pointed outwards, I swapped their positions so they fired inward. Big bass improvement.
I was still concerned about the honky midrange and harsh high end: I backed off the L-Pad settings a little and that helped some.My wife came down to check them out I played selections from a number of discs, primarily these were hi-res recordings (SACD and DVD-a and a few redbook discs). After about an hour I noticed some improvement in the overall sound quality and that the bass had really clicked into place. The high-end harshness was still evident but decreasing, midrange was still a little lean.I put a disc on “repeat” and came back a few hours later. The improvement was notable. The next few hours I continued sampling my music collection and I was stunned by the resolving power of these speakers. The bass continued to improve. I stayed up well past my bed time as I surveyed recordings on LP, CD and sacd/dvd-a. LP reproduction was amazing given that I am using a 30 year old Harman Kardon tt and a $40 grado cartridge (5 yearsold). Redbook CDs just don't cut it, but I already knew that.I put my player on repeat for the night. I dropped in briefly this morning to change discs (Mahler 9th) and listened to it briefly. Amazing how the individual instruments can be heard in comparison to how my 20 year old Infinity Kappa 8's could not. I also reset treble and midrange controls to the 12 and 12:30 positions. Time (wife) did not allow for listening session however.
So my plan is to continue 24x7 burn in for this week and revisit next Friday night. I will use an old tuner I rarely use as a source instead of my Pioneer 79 avi player. Next week I will work on positioning, l-pad tweaking if needed etc. I plan to leave the putty pinching business until last.Btw, the electronics in my system are van Alstine Fet Valve preamp, van alstine 440 exh power amp (220 watts/channel). Kappa 8's are now back channels with van alstine Omega 3 poweramp.I also looked on the vmps website for a manual but did not see one. Is it available for download somewhere?
I look forward to next weekend sessions. I heard moments of magic in the past 24 hours and can't wait to see how the sound “matures” as break-in hours accumulate.ge
I get the best midrange balance if I elevate the front of the speaker 1/2-3/4 inch by placing a slat of wood that thickness under the base a couple of inches from the front. I use a cross fire toe in as B recommends, crossing 18-24" in front of the listening position. I get excellent midrange balance this way.
After 3 1/2 years, I'm still finding ways to make mine even better.
So my advice is to be patient. These speakers are fine tuneable in many more ways than most speakers. Level controls come first (mine are at 11:40 mids, 11:00 tweeters). I am using the rear ambience tweeter, so that adds some top end. I don't use the waveguides for serious listening; when I do use them I turn the controls all the way up. Cabling has been a revelation to me. I use Clear Day silver for the mids and highs, large guage OFC cables for the woofers.The putty can really help balance out the bottom, and of course distance from walls (at least 18" behind the speakers and 3 feet to the sides if you can do it).Be patient, work away at it, and when it snaps together you should get great results, although taste is the final cut, of course.When I think about what speakers from other cos. I should consider to get better sound than these in this size class, the choices start at over $10k and go up drastically in price. At $2k there is no used competition at all.Above all have fun!
Hello again!A couple weeks have already slipped by since my initial posting and I am overdue for providing an update.I have burned in the speakers 24x7 for the past two weeks. I used two sources: fm tuner (sometimes tuned to a station sometimes beween for 'white noise'). Usually i put a SACD on repeat, changing the disc each day. Why? Why not?The transformation over these two weeks is remarkable! The midrange honk is gone, the hard high end is all but gone (very recording dependent). Bass has found depth and solidity (no putty pinching yet).In my acoustically treated room the overall sound is sensitive to speaker placement. For the time being the back edge of the speaker bases are about 6 inches from the front wall and the speakers are toed in to cross in front of my listening post. Woofers fire inward. So far this provides the best overall presentation. Waveguides = on. Some interesting observations – I am hearing some remarkable recordings of remarkable music. I kinda expected to be blown away by some of the well-regarded 'modern' recordings, ones without brickwalling and smiley EQs. And some of these are fine. But it was some of my LPs from the early to mid 70's and the hi-res dvd-a/sacd productions of recordings of this time period that blew me away:Strongly recommended are King Crimson “Lizard” dvd/a, David Crosby “If Only i Could Remember My Name” dvd/a,
Graham Nash “Songs for Beginners” dvd/a, Pere Ubu “Modern Dance” dvd/a (no kidding folks), Roxy Music “Avalon” sacd, McDonald & Giles LP, Blondie “Plastic Letters” and “Parallel Lines” LPs, Elvis Costello “Trust” F-Beat LP, Lou Reed “Blue Mask” LP, Genesis "Lamb Lies Down" LP are ones that spring to mind. And Frank Zappa's “Halloween” on dvd/a has some great examples of how good a guitar in the early 1970's could sound. I look forward to exploring my musical library again this weekend. I wish I had analog tape....
Thanks again for all of your suggestions and words of encouragement in the early goings of break in. Much appreciated. I will continue to adjust the mid panel and tweeter controls as outlined here, and of course speaker placement. I may even try the woofers outward again.
One more question – I will be at some point in the not too distant future be looking for a multichannel preamp with analog 5.1 in and out capability. I don't need processing, that will be handled in the player. I know of the Bryston sp2, Bel Canto Pre 6 and Paragon p7. Does anyone here have experience with any of these with VMPS speakers? ge
It might be worth you looking at this thread:http://www.audiocircle.com/index.php?topic=22154.0
[...]But what really sent me to Nirvana was when my wife offered to let me try her Bryston integrated amp (st100?). Much fuller bass, creamy midrange and greater high end detail but without that element of hard edge that had remained with my previous electronics. It was a revelation. [...]
