DIY Dodd Buffer
Mariusz
Re: DIY Dodd Buffer
« Reply #340 on: 30 Apr 2010, 02:47 am »
Thanks guys!!!
No, won't sing tonight.
Just put a light walnut stain and plan on finishing it with few coats of Watco (walnut piece right under was finished the same way)
Eventually, clear top will be replaced with aluminium or copper plate.
This box project started out as experimental research for cheap and quick kit assembly. To be honest, it was (is) a lot of fun and it looks somewhat decent too.
Best of all:
- $8.99
- compact
- tube rollable
......those light maple knobs, DODD logo and maple finished remote will be just
icing on the cake! :drool:
 :wink:
gld
    • http://doddaudio@live.net
Re: DIY Dodd Buffer
« Reply #341 on: 30 Apr 2010, 02:08 pm »
Nice work Mariusz! :thumb: What size are the knobs yuo needing?
Gary
poseidonsvoice
    • 2 channel/7 channel setup
Re: DIY Dodd Buffer
« Reply #342 on: 30 Apr 2010, 02:12 pm »
Gary
received caps & pin header.
Back in bussines.
and some pics:
 :wink:
 :notworthy: :drums: :beer: :bounce:
That about sums up what I feel about the above build.
Anand.
gld
Re: DIY Dodd Buffer
« Reply #343 on: 30 Apr 2010, 03:50 pm »
I'll be makin some maple knobs this weekend :drool:
Gary
Mariusz
Re: DIY Dodd Buffer
« Reply #344 on: 30 Apr 2010, 04:32 pm »
Gary
Sounds great Gary.
Any chance of DODD logo :wink:
(to save on shipping :lol:)
Mariusz :wink:
Mariusz
Re: DIY Dodd Buffer
« Reply #345 on: 1 May 2010, 12:02 am »
Gary
Change of plans(hope it's not too late)
The size of knobs I gave you in my previous post will overpower the front and may block remote's reciver.
If possible, the correct size will be:
2 knobs - 1.5" in diameter and 1" thick
1 knob - 1" in diameter and 1" thick
Sorry for miscalculating it.
Now, with the unit in hand the picture is clear.
Original size just wouldn't work very well.
Mariusz
« Last Edit: 1 May 2010, 04:01 am by Mariusz »
TrungT
Re: DIY Dodd Buffer
« Reply #346 on: 1 May 2010, 12:41 am »
Mariusz
Just talk to Gary, he's making your knobs but .... , He going to make the new one as your requested.
 :thumb:
Mariusz
Re: DIY Dodd Buffer
« Reply #347 on: 1 May 2010, 03:29 am »
Mariusz
 :thumb:
If Gary made the ones in original size already, no problem Ill take them as well. Those might not be suited for this enclosure but I do have at least two other DIY components which need some makeover. :wink:
Mariusz
dmatt
Re: DIY Dodd Buffer
« Reply #348 on: 1 May 2010, 03:52 pm »
FYI for those that haven't purchased a C-Tek charger yet.
Amazon (no affiliation, yada yada) has the US 800 for sale for 33.50 with free delivery.
http://www.amazon.com/dp/B002QUT8IC/ref=pe_68490_15229660_pe_epc_d8
Sweet.
David
parodielin
Re: DIY Dodd Buffer
« Reply #349 on: 1 May 2010, 04:09 pm »
Quick question, what's the size of mounting hole of the Alps Pot?
Mariusz
Re: DIY Dodd Buffer
« Reply #350 on: 1 May 2010, 04:20 pm »
I think it's 3/8".
gld
Re: DIY Dodd Buffer
« Reply #351 on: 1 May 2010, 06:20 pm »
5/16" if you are not using the shoulder washers. 7/16" if you use the shoulder washers. Mounting hole for volume pot.
gary
Robert F.
Re: DIY Dodd Buffer
« Reply #352 on: 2 May 2010, 02:15 pm »
Gary,
 Can you tell us how the various tube generally sound with your buffer? I know each persons system will be different but a little direction for us new to tubes can be of some help.
Robert
gld
Re: DIY Dodd Buffer
« Reply #353 on: 2 May 2010, 03:50 pm »
Robert as you said all systems are different! I will try and describe the tubes that I prefer in my system. Somewhere in this thread there is a list of tubes that were tried with the buffer, all of the tubes listed will work with it, but I can't say how they sound as I don't know I just tried them to see if they would work. I'll leave trying them to you guys. Never know there may be a great tube there somewhere. I have used 3 different tubes in my system. I used a Tele 12AX7 smooth plate, RCA clear top 6FQ7 and a JJ E88CC. My system consists of a pair of Danny's V-1's, Squeezbox Duet, a modded Wolfson DAC (HAL) my buffer and most of the time a battery amp. Note everything is on battery except the sub amps, and they are powered thru a PI Audio Sub-Buss. Sometimes I listen to vinyl thru my battery phono stage.
My TT rig is a Sumiko Project with the carbon fiber arm and a Blackbird Cart.
I'll start with the Tele 12AX7, this tube has a very smooth sound to it with a nice extended top end. The bass is good but not a tight as I would like it to be. The midrange is so smooth and natural sounding, but it's not really exciting to me to listen too, it may be due to the very hi output impedance of over 500 ohms.
The RCA clear top solved all the bottem end problems with a fast really tight bass with exceptional extension in the bottom octaves! The draw back was everything else was laid back sounding and not nearly as smooth as the ax7. I would say this tube would be good for loud rock and roll but definately not for criticle listening!
My favorite and MOST musical tube is the JJ ECC88, who'd of thought that!This tube has everything of the other 2 tubes, but it is very very musical in my system period! It works well with all types of music and you never get tired of listening to the system. Extremely hi resolution and killer bottem end!
I am pretty sure that there are many tubes that are currenlty not being used for audio that will work in this buffer and some of those may be real sleepers that no one knows about! I will count on you guys for finding those treasures and let everyone know, cause I sure don't have the time to do it myself.
Hope this helps.
Gary
praedet
Re: DIY Dodd Buffer
« Reply #354 on: 2 May 2010, 07:36 pm »
All right, so everything is almost ready for assembly in the Dodd Chassis (when it gets here :))
So how exactly should I be using the zip ties?  I didn't see that in the instructions anywhere.
Also, any chance of showing some nice shots of exactly how everything looks in your chassis Gary, especially how they are mounted and wired?
TrungT
Re: DIY Dodd Buffer
« Reply #355 on: 2 May 2010, 07:40 pm »
Praedet  :thumb:
You can use the zip ties anyway you want  :wink:
One here:
and more here: http://doddaudio.com/DIYINSTRUCTION.aspx
Hope that help.
gld
Re: DIY Dodd Buffer
« Reply #356 on: 3 May 2010, 01:00 am »
preadet I'll try in the next few days getting some pics of an assembled unit in the real chassis for you guys that have puchased the chassis and would like to see how it goes. :thumb:
gld
Re: DIY Dodd Buffer
« Reply #357 on: 3 May 2010, 01:06 am »
Mariusz here are some knobs for you
 :drool: :drool:
Oh yea, would this be up to everyones standards for a logo on a kit???? :drool:
It is 1.5" by 3" gloss black on brass and it has good double sticky tape already on it! :thumb: Just peel and stick!
Gary
Mariusz
Re: DIY Dodd Buffer
« Reply #358 on: 3 May 2010, 03:56 am »
Oh my!!!! Those look tasty !!! :drool:
Love the logo as well. Just about punching out (11:53pm) from work..... been a little busy ....... building DODD buffer. :wink:
Not sure if it will light up or blow up but I'll certainly test it tomorrow.
Thank You Gary
Mariusz :thumb:
P.S
PM send
« Last Edit: 3 May 2010, 05:07 am by Mariusz »
TrungT
Re: DIY Dodd Buffer
« Reply #359 on: 4 May 2010, 02:01 am »
Mariusz
Is your Dodd Buffer singing yet?
