0 Members and 2 Guests are viewing this topic. Read 306257 times.
maybe I have room for battery operated tube amps sometime in the future.Sweet.David
Not a problem at all...as long as it's a sealed AGM you're fine. 31 AH will last a looooooooong time.I use a 28 AH.
jtwracewhat is the max. play time with your 28Ah???My battery is half that size - so obviously I'm curious.Mariusz
At 12hrs I shut it off...still more to go though.
Alright, so for 14Ah, it would be somewhere around half...... depending on ???????
Mariusz, with the 6N1P I ship with each kit you'll probably be able to get 12 hours or so of operation. Any other tube will not use nearly as much current and will last much longer. Example would be a 12AX7, it would go around 30 hours or so.On another note if you are using a good smart charger you can go forever and not worry about it!It is a 1 tube unit now.Gary
jtwracewhat is the max. play time with your 28Ah???My battery is half that size - so obviously I'm curious.As to buying 2nd unit. This will have to wait for just a bit. But at this (and 2-3X) price point there is not much to choose fromwhich makes it NO BRAINER!Mariusz
Ed13.5 hrs, wow, Very good.Thanks for the info.
Gary received caps & pin header.Back in bussines.
