DIY Dodd Buffer
0 Members and 1 Guest are viewing this topic. Read 306288 times.
TrungT
Re: DIY Dodd Buffer
« Reply #300 on: 28 Apr 2010, 03:55 am »
Mariusz
Looking good so far  :thumb:
I like the way you drilled at the RCA jack, you may give the socket a try instead the needle nose. :wink:
Few more wires, She will sing your favor tune.
 :thumb:
Mariusz
Re: DIY Dodd Buffer
« Reply #301 on: 28 Apr 2010, 11:17 am »
Mariusz
 :thumb:
You're right, ratchet might have been easier.
•box is the cheapest solution I found - $9 IKEA.
link to planter box
Needs to be trim few inches of the top tho (pics coming later today)
•tools needed - ratchet set or long nose pliers, drill bit set, table saw or hand saw + stady hand, electric or battery drill.
Have fun
 :wink:
Edit- added link
« Last Edit: 28 Apr 2010, 03:08 pm by Mariusz »
mikeeastman
Re: DIY Dodd Buffer
« Reply #302 on: 28 Apr 2010, 01:11 pm »
Mariusz, what are the sizes of the bits for all the holes and how thick is wood in your box? I'm planning to try to make a box or at least part of the box out of stone, I have some granite, marble and sandstone on order and want to get any diamond bits I will need ordered. Thanks for all the good info.
ebag4
Re: DIY Dodd Buffer
« Reply #303 on: 28 Apr 2010, 06:21 pm »
Hey Ed That 6N1P is the highest filament current out of all the tubes coming in at close to 1 amp. A 12AX7 uses 150 milliamps and I use a 6DJ8 that uses  about 360 ma. 12 volt tubes will have a lesser filament current than most 6 volt tubes, and yes when you use a 12 volt tube the reg is doing nothing.
Gary
Thanks for the info Gary.  I have a 5751 Sylvania Gold Label Black plate - triple mica - "D" getter halo in the buffer right now and it is sounding mighty fine!  Funny, I didn't lke this tube in my Jolida 102B.  I will update this post with the milage I get from the 5ah battery using this tube.
Best,
Ed
Mariusz
Re: DIY Dodd Buffer
« Reply #304 on: 29 Apr 2010, 01:55 am »
3/8" and 5/8"
1/2" if you need a bit extra room in case of slight screw ups.
Hope it helps.
Gary
a quick question:
Just got some woofers and plate amp from Danny and wonder if
running speakers and subs presents any issues?
Mariusz
TrungT
Re: DIY Dodd Buffer
« Reply #305 on: 29 Apr 2010, 02:44 am »
Knobs for my buffer.
It's made to fit with Dodd buffer.
 :thumb:
gld
    • http://doddaudio@live.net
Re: DIY Dodd Buffer
« Reply #306 on: 29 Apr 2010, 03:02 am »
Mariusz, no problems that's why there are 2 sets of outputs. it will work just fine. :thumb:
gary
Mariusz
Re: DIY Dodd Buffer
« Reply #307 on: 29 Apr 2010, 03:21 am »
 :thumb:
who makes those.
NICE!!
gary
thanks Gary
Mariusz  :thumb:
TrungT
Re: DIY Dodd Buffer
« Reply #308 on: 29 Apr 2010, 03:26 am »
I ordered from Gary, I think he going to add to the website soon.
Slightly more than 1/2 off the Chrome knobs.
 :thumb:
Mariusz
Re: DIY Dodd Buffer
« Reply #309 on: 29 Apr 2010, 03:29 am »
 :thumb:
I am in for two sets.  :drool:
Dark/light options or .......?
TrungT
Re: DIY Dodd Buffer
« Reply #310 on: 29 Apr 2010, 03:40 am »
I think Gary going to make few wood type and few color choices.
So when your buffer going to sing Mariusz?
Mariusz
Re: DIY Dodd Buffer
« Reply #311 on: 29 Apr 2010, 04:45 am »
Great news. Love those wood knobs ..... and the price is right.
As to when my kit will sing well, as soon ad I get those by-pass caps and pin header which I destroyed in the process of de-soldering it from the board.
(I have to say, Gary is very helpful and patient in the process  :thumb:)
If all goes well, I will have it sing by the end of the weekend.
a bunch
Mariusz
TrungT
Re: DIY Dodd Buffer
« Reply #312 on: 29 Apr 2010, 05:07 am »
 :duh: Oh Yea OOPS
Friendly remind:
Make sure your battery fully charged.
For mean time you can make the power cable and ready to hook up the battery
 :thumb:
etcarroll
Re: DIY Dodd Buffer
« Reply #313 on: 29 Apr 2010, 10:53 am »
Gary -
Would a 5670 396A 2C51 RAYTHEON WINDMILL GETTER work in this?
I just picked up an older Bryston 4B, need a pre for it. I bought the above tubes for testing with a tubed DAC and liked the sound of them.
gld
Re: DIY Dodd Buffer
« Reply #314 on: 29 Apr 2010, 02:02 pm »
The 5670, 396/2C51 will not work in the buffer. They all have a different pinout. :nono
Gary
etcarroll
Re: DIY Dodd Buffer
« Reply #315 on: 29 Apr 2010, 03:00 pm »
Gary
Thanks for the prompt response. I'm kinda fascinated by this project, is the AC members pricing and free shipping still available?
gld
Re: DIY Dodd Buffer
« Reply #316 on: 29 Apr 2010, 03:58 pm »
Sure is! :thumb:
Gary
Mariusz
Re: DIY Dodd Buffer
« Reply #317 on: 29 Apr 2010, 04:05 pm »
Sure is! :thumb:
Gary
:dance:  :drool:  :dance:
Gary
please sign me up for those cool wood knobs.
If possible, in maple - both sets.
 :drool:
Mariusz
Re: DIY Dodd Buffer
« Reply #318 on: 29 Apr 2010, 04:18 pm »
:duh: Oh Yea OOPS
Friendly remind:
 :thumb:
Sure will.
Just checked.
I have one 12V14Ah battery on its way (it is relatively small and might fit in the same enclosure)  and emergency back up - 12V17Ah (not as compact).
If it sounds very good, I'll probably get another one for 2nd system.
Mariusz :wink:
jtwrace
    • TIPP YouTube Channel
Re: DIY Dodd Buffer
« Reply #319 on: 29 Apr 2010, 05:17 pm »
Mariusz :wink:
You might as well order it now.   :thumb:
