No secrets...just more drool with the bypass caps.
How $ are those upgrade caps?Might get some of those and others to roll. Any other recommendations???
I agree 1,000,000%!I also see that you did the Sonic Platinum bypass upgrade. Good idea as I was shocked at the difference. I purchased mine when they first came out (assembled) and then did the bypass upgrade. I have even more I HIGHLY recommend this to all.
The upgrade to Sonicap Platinums as a bypass cap . It wires across the original 3.3uf Sonicap. The value of the cap is .01uf and it's a Sonicap Platinum. It DOES make nice differences sonically. The best part is , it is a nice improvement for cheap ($40) for a pair of them gary
Ed that would be quite tough to tell you the equation. I use a spice modeling software and the computor to determine the output impedance. I really don't mind inputing all the specs and giving you an answer on any tube as lond as I can find the spec on it. Heck that way even I get to learn something and build a better tube info base Gary
