DIY Dodd Buffer
0 Members and 2 Guests are viewing this topic. Read 305409 times.
jtwrace
    • TIPP YouTube Channel
Re: DIY Dodd Buffer
« Reply #140 on: 13 Apr 2010, 02:31 pm »
For powering the buffer alone I recommend a 12 volt 26AH battery and a good quality smart charger like the C-Tek that is available from many sources.
gary
+1
 :thumb:  See my post above #130.  That's what I use...
charger purchase link:  https://www.shopatron.com/products/productdetail/part_number=56-171/560.0.23205.0.0.0.0
praedet
gld
    • http://doddaudio@live.net
Re: DIY Dodd Buffer
« Reply #142 on: 14 Apr 2010, 12:57 am »
Mariusz I pm'd you earlier. I can't send you a buffer tomorrow without an address? :scratch:
Gary
Mariusz
Re: DIY Dodd Buffer
« Reply #143 on: 14 Apr 2010, 01:08 am »
Gary
Hi Gary
PM send and big thanks for
making this kit available.
Cheers
Mariusz  :thumb:
sl_1800
Re: DIY Dodd Buffer
« Reply #144 on: 14 Apr 2010, 02:22 am »
Gary,
I sent you two PM's on my shipping address.  I made a mistake in the first one. :duh:
TrungT
Re: DIY Dodd Buffer
« Reply #145 on: 14 Apr 2010, 07:03 am »
 :drool:
Can't wait ......
 :weights:
I'm ready
firedog
Re: DIY Dodd Buffer
« Reply #146 on: 14 Apr 2010, 08:16 am »
+1
Does anyone know of a charger like this that one can also use and keep the buffer or whatever unit plugged in? That is a smart charger that charges the battery but lets you run off of current when desired?
jtwrace
Re: DIY Dodd Buffer
« Reply #147 on: 14 Apr 2010, 11:14 am »
I actually use this charger and don't disconnect it.  Honestly, I don't hear a difference with it connected or not.  Mr. Dodd what are your thoughts?
jkelly
Re: DIY Dodd Buffer
« Reply #148 on: 14 Apr 2010, 12:11 pm »
Can the tube modules wire connectors be placed underneath (flipped) to
accommodate mounting tubes on top of case?
Jeff
gld
Re: DIY Dodd Buffer
« Reply #149 on: 14 Apr 2010, 02:46 pm »
Firedog, I recommend the C-TEK brand smart chargers. I use a model US-7000. I have it connected to the batteries and plugged in all of the time. I cannot hear any differences at all between plugged in and not plugged in. Also this way I never have to worry about the batteries being mistreated. :thumb:
Jeff, I would have to redesign the module to do that, the way it is now it cannot be mounted from the top.
dBe
    • PI audio group, LLC
Re: DIY Dodd Buffer
« Reply #150 on: 14 Apr 2010, 03:11 pm »
My C-tek is silent, at least to me and the half a dozen audiophools that frequent my place.
Highly recommended.
Dave
Mariusz
Re: DIY Dodd Buffer
« Reply #151 on: 14 Apr 2010, 04:33 pm »
Gary
check your PayPal.  :thumb:
and........thanks for all your help/assistance.
Having remote control handy will make listening to music a lot more enjoyable.
Regards
Mariusz :thumb:
gld
Re: DIY Dodd Buffer
« Reply #152 on: 14 Apr 2010, 08:21 pm »
First 5 kits shipped!!! :green: I can't wait to see what you guys think of it! :thumb:
gary
Mariusz
Re: DIY Dodd Buffer
« Reply #153 on: 17 Apr 2010, 03:05 am »
Recieved it today. :thumb:
That was fast.  :scratch: ....  :P
ebag4
Re: DIY Dodd Buffer
« Reply #154 on: 17 Apr 2010, 03:21 am »
Received miine too! :thumb:
face
Re: DIY Dodd Buffer
« Reply #155 on: 17 Apr 2010, 01:36 pm »
Shouldn't this be in "The Lab"?
jtwrace
Re: DIY Dodd Buffer
« Reply #156 on: 17 Apr 2010, 01:37 pm »
At this point it should be in both areas.  The Lab will be needed when it's time for questions on assembly.
It is Cheap and Cheerful though   :thumb:
sl_1800
Re: DIY Dodd Buffer
« Reply #157 on: 17 Apr 2010, 02:21 pm »
Gary,
Is there a limit to the length of cables the Buffer can run?
Mariusz
Re: DIY Dodd Buffer
« Reply #158 on: 17 Apr 2010, 04:41 pm »
No.
As a complete kit with straight forward instractions ???.....again, No.
Build details, mods, tech questions can be posted in the Lab.
(this is introduction to affordable product but I won't ban  :duh: anyone for asking a simple/inocente question).  :wink:
Mariusz :)
gld
Re: DIY Dodd Buffer
« Reply #159 on: 17 Apr 2010, 05:36 pm »
The only limit to the length of the cables depends on the tube being used. For instance with a 6DJ8 the output impedance is 88 ohms, you could drive really long cables without issues, but with a 12AX7 who's output impedance is 505 ohms, there could be some issues driving long cables. You would have to give it a try and see what happens.
Gary
