DIY Dodd Buffer
TrungT
Re: DIY Dodd Buffer
« Reply #120 on: 12 Apr 2010, 04:34 am »
jkelly
Re: DIY Dodd Buffer
« Reply #121 on: 12 Apr 2010, 11:48 am »
Is there a top down picture of a completed DIY unit available?
Jeff
jtwrace
    • TIPP YouTube Channel
Re: DIY Dodd Buffer
« Reply #122 on: 12 Apr 2010, 11:57 am »
Jeff
see the links that I posted on reply #58.  I've taken some close ups of my buffer.
or use these
http://www.audiocircle.com/index.php?topic=75028.0
http://www.audiocircle.com/index.php?topic=74866.0
Big Red Machine
Re: DIY Dodd Buffer
« Reply #123 on: 12 Apr 2010, 12:00 pm »
If using a wooden box, how many devices need some sort of grounding scheme that the metal box would provide (electrically)?
Any thermal issues needing heatsinks on any devices with a wooden box?
gld
    • http://doddaudio@live.net
Re: DIY Dodd Buffer
« Reply #124 on: 12 Apr 2010, 02:45 pm »
Actually the way I have it built there is nothing that is in direct contact with the chassis. There is a ground buss that all the grounds connect to.
Nothing gets hot, so no heatsinking needed. Also the tube just gets warm, not hot to the touch so it's not even a problem inside a closed enclosure with little venting.
In the next couple of days I will show a pic of how it would look inside an enclosure. That way you can get an idea of the wire routing and such. :thumb:
Gary
ebag4
Re: DIY Dodd Buffer
« Reply #125 on: 12 Apr 2010, 02:47 pm »
Gary,
What about the voltage regulator on your Main Wiring sheet that you note "Mount To Chassis For Heatsinking", should we come up with a heatsink if using a wooden enclosure?
Ed
praedet
Re: DIY Dodd Buffer
« Reply #126 on: 12 Apr 2010, 02:57 pm »
Would a set-up like this from redwine.com work for power?
jtwrace
Re: DIY Dodd Buffer
« Reply #127 on: 12 Apr 2010, 03:10 pm »
Of  course but why spend that much on the power?  Look at what you'll be spending on the item that actually makes the sound.  I don't think the BL will make the buffer sound any better then a 12V battery hooked up to the buffer.
gld
Re: DIY Dodd Buffer
« Reply #128 on: 12 Apr 2010, 04:00 pm »
Ed, Thanks DUH I forgot about the reg! Heck just a small piece of aluminum about 2" square and 1/8" thick would be plenty, or a small heatsink. :thumb:
Gary
gld
Re: DIY Dodd Buffer
« Reply #129 on: 12 Apr 2010, 04:04 pm »
You could use a Red Wine battery supply if you wanted to. There will be no difference sonically. :nono: I would prefer you use a good AGM type battery and a good quality smart charger. Doing so you can connect the charger and leave it connected and plugged in all the time. Sonically you can not hear it and you never have to worry about your battery going dead. :eyebrows:
Gary
jtwrace
Re: DIY Dodd Buffer
« Reply #130 on: 12 Apr 2010, 04:10 pm »
Like what I did?
dBe
    • PI audio group, LLC
Re: DIY Dodd Buffer
« Reply #131 on: 12 Apr 2010, 08:53 pm »
Gary
I have a 100AH AGM battery and a C-TEK charger set up and it is sweet!  Just sits there, making no noise, making everybody happy  :dance:
Here I am, the guy with the A/C solution to noise and I'm a Dodd Battery Dood.  Who knew?
High quality audio reproduction is ALL about the elimination of noise in the power supply.
Gary, you TOTALLY ROCK!!!
 :thumb:
Dave
praedet
Re: DIY Dodd Buffer
« Reply #132 on: 12 Apr 2010, 09:07 pm »
Where is everyone getting their battery from?
Robert F.
Re: DIY Dodd Buffer
« Reply #133 on: 12 Apr 2010, 10:07 pm »
How do you think two 6 volt lanteren batteries would work and how long do you believe they would last?
Robert
Mariusz
Re: DIY Dodd Buffer
« Reply #134 on: 12 Apr 2010, 10:19 pm »
Like what I did?
I've ordered a similar charger. Should be here tomorrow.
Got some extra batteries - 12V 17AH and some golf cart replacements to test the kit.
But I would also like to know a reliable brand and source for batteries as well.
There seems to be a big difference in quality between brands and some sources that sells those batteries, keeps them on shelves way to long.
Mariusz
gld
Re: DIY Dodd Buffer
« Reply #135 on: 12 Apr 2010, 10:23 pm »
I get all my batteries from a place called batteryplex.com. They have nearly all of the brands and their service is really good! :thumb:
I have been using them for well over 2 years and have had NO bad batteries.
Gary
gld
Re: DIY Dodd Buffer
« Reply #136 on: 12 Apr 2010, 11:48 pm »
Robert
2 6 volt lantern batteries in series would actually work, but depending on the tube used I don't think you should expect more than 3-4 hours on them, maybe less
Gary
HAL
Re: DIY Dodd Buffer
« Reply #137 on: 12 Apr 2010, 11:49 pm »
+1 for Batteryplex.  Gary told me about them when I needed new units for my Dodd battery preamp.  Fast service and great prices!
Robert F.
Re: DIY Dodd Buffer
« Reply #138 on: 13 Apr 2010, 09:23 am »
Robert
Gary
Thank you for the info. What amp hour rating would you recomend to get good battery life?
Robert
gld
Re: DIY Dodd Buffer
« Reply #139 on: 13 Apr 2010, 02:25 pm »
For powering the buffer alone I recommend a 12 volt 26AH battery and a good quality smart charger like the C-Tek that is available from many sources.
gary
