0 Members and 1 Guest are viewing this topic. Read 18275 times.
I already have a Nokia 770 that functions fairly well for this, though.
Not even close. I had a N800 which I am sure was faster then 770 and it was SLOW. The ipod(I use the phone) with Squeemote is in a different leauge.
Bob, you can find 2nd generation ipod touch's and even newer ones on Craigslist (my name is not craig)...I see them all the time pretty cheap, if its just to control a Squeezebox you might want to check there. These little puppies come in handy...its off topic but I personally think the ipod touch/phone is the coolest gadget ever made so far in my time!! I do remember phones with dials and cords, my first cable box was connected to a 20 ft. cord and was about a foot long and I thought that was "LIVIN"!!
Bob,Take a look through this thread. It might have something that should work with your son's PSP.For those of you with wireless networking problems with the DUET, you might try rotating the case 90 degrees. The wireless antennas internal to the DUET are oriented horizontally. You might be able to obtain better reception if they were turned vertically. Just turn the case on it's side to see if that might help.I do offer an external antenna mod for the DUET.
Am I correct that the remote talks to the receiver "through" the router? I think this is what I remember and if so a better receiver antennae would probably not have helped the situation.
Good question. I'm curious as well.Bob
she did finally confirm that the unit will work just by plugging in a usb drive.
I do not know why you would need a computer now. Anyone have a reason to use a computer?
It was frustrating but she did finally confirm that the unit will work just by plugging in a usb drive. That is great news and definitely lowers the cost to stream! In fact, I do not know why you would need a computer now. Anyone have a reason to use a computer?Cheers,James
