0 Members and 1 Guest are viewing this topic. Read 385088 times.
I think if I had it to do over again I'd be tempted to go with the 9V rechargeable battery set up mentioned earlier. Neil
I have found that the 4-1k resistors have quite an effect with the B1. Im surprized it isnt mentioned a whole lot, seems to be a bigger issue on the dcb1 thread. Im sure it is somewhat system dependant but good parts in this location should be considered.I have tried several different resistors so far and awaiting some naked Vishays now.Takman carbon film- great bass and dynamics, warm and smooth but lack transparencyPrp metal film- smooth and transparent but lacks dynamicsRiken carbon film- great resistor with good transparency, smooth, awesome bass and dynamics. I think i could live with all 4 Rikens but some say use in moderation. Naked Vishay(TX2575)- report backI am going to try the Vishays as the input resistor and have the Rikens on the output right now, hoping that will be a good balance with awesome transparency. I will also note these results are based upon 330r.
Looksey what i got today! I am going to hold off on comment till i give'em and few hrs breakin but i will say they seem to live up to all the hype.
Nick,Did those go in R105 and R205? Thanks.James
Any noticeable audible difference?
No, the Vishay's are in the input position R102 & R202. I have Rikens in the output R104 & R204.It should be noted that Scott tried Rikens in both positions and wasnt favorable results. They seem to only play well in the output, use in moderation seems to apply. Having a good transparent neutral resistor like the TX2575 in the input seems to be key.
Nick,OK so those are just the 1K ohm ones. Thanks for your reply.James
Yes the 1k resistors are the ones in the signal path and one should consider premium parts in this position. Again my results are using R330 instead of 1k.
