0 Members and 2 Guests are viewing this topic. Read 385061 times.
IIRC from calculations I did last year ( and I've slept since then ) A pair of 9V Alkaline batteries would last around 420 hrs ( I think ). An On/Off Switch, and a couple of battery connectors is all that is required to try it out.That being said, there may be something to the capacity of the SLA batteries that would affect the resultant sound too.....John
Or you can get the two Hi Tech Li Ion 9VDC/600mAh batteries and dual charger from Batterymart for $37
I am wondering were most folks picked up their RCA connectors from? Thanks.Added info:I found these in the B1 thread at diyaudio which look good and do not cost that much.http://www.futurlec.com/RCA-ChassIns.shtmlJames
Question for all those using 24v to power their B1,Did you upgrade the voltage rating on the power supply caps from the spec'd 25v??Also is there a sonic benefit to using 24v instead of Nelson's 18v?I'm trying to decide between 18 or 24v for my project...
Would this preamp work with my Red Dragon Amp-1 that have 10k input impedance?
