0 Members and 2 Guests are viewing this topic. Read 385636 times.
Would these PNP 1K resistors be a good choice? http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=PNP100JR-52-1R-ND
Thanks, sorry I was confused. I looked up the wrong ones, should have been PRP. I there anywhere that sells them that uses parcel post and doesn't have a minimum order?Which series of PRP? The have several. Thanks!
Excellent! Now where are the pics !
Its ALIVE! Wushuliu you hatched another one, many thanks for your support. Right out of the box it sounds really good, already getting very good bass and clean sound. Cant wait to put a few hours on it.
This is actually another complete b1 with the sonicaps. The other one has the dayton 1% caps and for the $ in this application I think the daytons would be hard to beat. Try bypassing the dayton 1% with the dayton film/foil caps if you want to experiment later.
Hey Avionic Are you saying you are liking the sound of the Daytons over Sonicaps. Regards, Scott
This is what I used: http://cgi.ebay.com/Aluminum-Project-Box-Enclousure-Case-Electronic-DIY-Big-/250597855778?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item3a58cbd222 Fits a little snug. He also has them in silver. I will post some pics tomorrow of my b1 mounted in this enclosure.
Hi folks - long time no post. Good to see that more and more people are building B1s and enjoying them.Earplay - how are you getting on?Wushuliu - The Hypnotize is a nice project - I built one of the prototypes and I should use it in my system but the LSA/B1 keeps playing music. So I will have to (finally) test my LSA point-to-point build and incorporate that into the Hypnotize.Apart from the track lifting on the prototypes (not a problem with the GB boards as the tracks were made much thicker) the only fiddly bit was setting up the LED strings.I agree with you about the DCB1 sound - it is like the B1 but more open and detailed - but the B1 is not in any way shamed.Alan
Search for this one on ebay DACT Type 21 Stepped Attenuator 20K FOR PASS B1 DIY and the knob is from Valab also from ebay.
Does that knob come with a set screw?
Just an update on the DC Coupled B1: The sound has settled into a very open, easy going delivery. As sondale mentioned it is more open and transparent than the regular B1. Audibly, audibly so. It is also more engaging - maybe the term is musical? - than my battery run B1, which itself is terrific. I find myself having a hard time analyzing it as my mind wanders and I forget to skip to other demo tracks. Get lost in it pretty easily. Really involving. Not really sure how to describe the improvement except that it's absolutely worth it. I would love a comparison with higher priced gear...
Wushuliu thanks for the update on the dcB1, im sure it has to sound better or it wouldnt exist but this B1 is absoluely blowing me away. It has taken over 150 hrs to finally open up which has been very fustrating but worth the wait. I used carbon resistors in the signal path and i kept wanting to remove 2 if not all cause it sounded so lifeless and muted. Well i heard from several buddies that carbon resistors can take 300 hrs to break in so i decided to stick it out and i am glad i did. What i am hearing now is a VERY smooth warm presentation that feels like an expensive tube preamp. I am in love, this little simple design rocks. Thanks again Wush for sharing, i would not have attempted it without your tutorial.
avionic,Are you still using DacT mono's on your other B1 board? How do they compare to the ebay stepped attenuator?Your project looks good, well done. Bet it sounds great!
