0 Members and 2 Guests are viewing this topic. Read 385062 times.
Sorry, what does R330 refer to?
I believe me means that he changed to a 330 ohm value instead of a 1K ohm, but I am sure Nick will clarifiy this.James
I just ordered all the parts that wushuliu posted on the first page. So the 4 1K resistors are Dale/Vishay type. 1% tolerance, 50 ppm. Are these decent parts?
I wouldn't be too concerned. I'm pretty sure that Nelson Pass used the Vishay RN55D type 1K resistors in his stock design. And, plenty of guys used the BOM list that Wushuliu suggested and are very happy with the result.
BTW, what gauge hookup wire do you guys recommend? Parts express has 18awg and 24awg.
Does anyone know where I can find a substitute for this power jack? I all ready have the wall wart below. I checked mouser but could not find one. Thanks.James
This one will fit flush and was recommended to me by another AC member.http://search.digikey.com/scripts/DkSearch/dksus.dll?lang=en&site=US&WT.z_homepage_link=hp_go_button&KeyWords=CP-011A-ND&x=19&y=21
Does anyone know where I can find a substitute for this power jack? I all ready have the wall wart below. I checked mouser but could not find one. Thanks.Power jack:http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=CP-037A-NDWall wart:http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=T987-P5P-NDJames
