Music Server
0 Members and 1 Guest are viewing this topic. Read 29630 times.
c_note
Re: Music Server
« Reply #120 on: 27 Apr 2010, 03:08 pm »
I'm sorry, my post above wasn't very clear.  I meant comparing the sound of a commercial CD played on the BCD-1 to a copy of that same CD burned to a computer drive, using software like the Exact Audio Copy referenced a few pages earlier.  I suspect that this is the most likely scenario for people who want to archive their investment in compact discs.  Good luck with the comparison, James, we eagerly await your findings!
werd
Re: Music Server
« Reply #121 on: 28 Apr 2010, 05:35 pm »
hi Werd,
I am going to try that tonight - I know it works great on Media Monkey and Foobar.
james
Hi James
Wandering if you got around to trying this?
werd
Re: Music Server
« Reply #122 on: 28 Apr 2010, 05:36 pm »
Use vinyl as the reference  :icon_twisted:
Nap.  :peek:
This is accurate, why are you hiding?
You want the dac to go pure analogue, or as close to it as possible. this isn't the case with red book.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Music Server
« Reply #123 on: 28 Apr 2010, 05:41 pm »
Hi James
Hi werd,
Yes tried it - does not work.  We are going to build IR into the BDP-1 digital Player to allow the BR2 to control the play list like it does with Media Monkey, Foobar and Itunes.
james
werd
Re: Music Server
« Reply #124 on: 28 Apr 2010, 05:47 pm »
Hi werd,
james
Thats good news.... did you try hooking up the bda to the computer via usb, while hooking up  the bdp1  via xlr also? that might work.
Napalm
Re: Music Server
« Reply #125 on: 28 Apr 2010, 05:47 pm »
[...] We are going to build IR into the BDP-1 digital Player to allow the BR2 to control the play list like it does with Media Monkey, Foobar and Itunes.
Hooray !!!!
 :bounce: :hyper: :thankyou: :bowdown:
Nap.  :thumb:
Re: Music Server
« Reply #126 on: 28 Apr 2010, 05:51 pm »
Yup tried that - doesn't work with the BDP-1 but does with the BDA-1 with Itunes, MM and Foobar etc.
james
Re: Music Server
« Reply #127 on: 28 Apr 2010, 05:57 pm »
Lorne,
How do you have yours hooked up?
james
Napalm
Re: Music Server
« Reply #128 on: 28 Apr 2010, 05:59 pm »
Because that's not accurate either.... you don't know what they recorded on that vinyl... I was just poking some fun at James....  :oops:
If you're asking me.... I guess James should arm himself with some sort of acoustic instruments (spanish guitar, drums, cymbals and whatever he could use to produce decent sounds with, without the need of actually knowing how to play them for real; violin is a no go,  eh?). And some really good LPCM recorder (shock and horror, it's Sony that makes a good one) and microphone. And do some recordings himself. Burn CD's. Play CD's. Play 24/96 file. Play the instrument through mic/amp/speakers. Play just the instrument. Listen. Compare.
Very difficult. But he might actually enjoy it, it could be fun too.
Nap.  :thumb:
werd
Re: Music Server
« Reply #129 on: 28 Apr 2010, 06:11 pm »
Oh sorry, my response wasnt clear. What i tried to say is, this is accurate about using vinyl output to reference, you were right.
Vinyl would be better than redbook  cd playback for comparison here.
cant quote atm ... buggy
werd
Re: Music Server
« Reply #130 on: 28 Apr 2010, 06:16 pm »
Lorne,
james
Hi
Always usb from laptop to bda..... can't understand why people bag out on it, the usb? mind you my RM-20 picked up the performance of my whole system so i guess usb is benefiting from this. Thats my take on it.
Napalm
Re: Music Server
« Reply #131 on: 28 Apr 2010, 06:20 pm »
Nothing related to audio performance.... but knowing how crappy the power supply and other electronics are in computers these day, I wouldn't let them have any electrical connection to my precious Bryston.... optical cable all the way.....
Nap.  :thumb:
werd
Re: Music Server
« Reply #132 on: 28 Apr 2010, 06:23 pm »
Nap.  :thumb:
I run on battery only, never plug in. the usb is much nicer than optical here, It really is. When my laptop goes dead so does my listening time. which is ok since i get about 2 hours, which is enough.
Re: Music Server
« Reply #133 on: 28 Apr 2010, 06:24 pm »
Hi werd,
I have the Mac Pro laptop hooked up optically and use the USB as well and that gives me the use of the BR2 remote on Itunes.
james
werd
Re: Music Server
« Reply #134 on: 28 Apr 2010, 06:33 pm »
Hi
There is something organic about the usb that i like. Mind you i havent tried the optical other than on my creative usb/coax-optical adapter which is starts out as usb.
i put so much attention into making this system  very responsive at casual listening levels. Aside from cabling and my 14B, my Torus put so much more jam into the soundstage that it seemed to offset my original usb complaint, it sounding a little wimped out.
Napalm
Re: Music Server
« Reply #135 on: 28 Apr 2010, 06:39 pm »
Hi werd,
james
Hi James,
I've already congratulated you for the choice.... now the question - are you intending to implement simple commands like "folder forward" "file forward" "play" "stop", so it could work in a minimal setup? Like just the media player + USB hard disk + BR2 (no computer or iPod Touch)?
Nap
Re: Music Server
« Reply #136 on: 28 Apr 2010, 06:42 pm »
Hi James,
I've already congratulated you for the choice.... now the question - are you intending to implement simple commands like "folder forward" "file forward" "play" "stop", so it could work in a minimal setup? Like just the media player + external hard disk + BR2 (no computer or iPod Touch)?
Valentin
Yes just the simple commands like Next, Previous, Stop, Play, Pause.
I load the playlist - turn off the lights - and use my BR2 remote like that now with Media Monkey and Itunes rather than the itouch.
james
Napalm
Re: Music Server
« Reply #137 on: 28 Apr 2010, 06:46 pm »
james
Cool. What happens if the hard drive does not contain any playlist? Just a bunch of .wav files? Will it be able to initiate playback of them (let's say in alphabetical order of filenames)?
Nap
Re: Music Server
« Reply #138 on: 28 Apr 2010, 07:05 pm »
Nap
Not sure on that  --- I assume it would need a playlist?
james
Napalm
Re: Music Server
« Reply #139 on: 28 Apr 2010, 07:15 pm »
james
In the minimalist setup I mentioned, it would be equivalent to an iPod Shuffle (you have no display, just play/stop/ffw/rwd controls). The Shuffle works with or without a playlist. If there's no playlist, it can play sequentially (alphabetical order of files).
Maybe you could check with engineering. It would be nice both for demos and real use if you could just copy one or more wav file(s) on a thumb drive, insert it into the media player and voila it plays music, without the need to create a playlist first.
If this is not possible and we really need playlist files, then the manual should have some info on the accepted playlist file formats, so we would know which playlists would be compatible and which not.
Nap.  :thumb:
