Music Server
0 Members and 1 Guest are viewing this topic. Read 29625 times.
myview
Music Server
« on: 18 Feb 2010, 01:46 am »
Hi James
More and more companies are introducing music servers in their product line.  Is Bryston considering to come out with one in the near future (say next 6 months)?  I am considering the offerings from some companies but if Bryston is coming up with one, I will probably wait and see!
  • The Demo is Everything!
    • http://www.bryston.com
quietdragon
1oldguy
Re: Music Server
« Reply #3 on: 18 Feb 2010, 02:15 pm »
I agree FLAC would be great.
myview
Re: Music Server
« Reply #4 on: 18 Feb 2010, 02:19 pm »
Hopefully, it can play Apple Lossless files as well
quietdragon
Re: Music Server
« Reply #5 on: 18 Feb 2010, 06:13 pm »
http://www.audiocircle.com/index.php?topic=69322.msg726046#msg726046
Please include Ethernet support and a publicly available command and control interface over TCP/IP.
Perhaps this would mean a developer API over this interface.
It would be great to be able to push content from my media server to the Bryston streamer.
Re: Music Server
« Reply #6 on: 18 Feb 2010, 06:16 pm »
Hi,
It will not have a streamer due to performance issues.
james
quietdragon
Re: Music Server
« Reply #7 on: 19 Feb 2010, 07:39 pm »
Not sure what you mean exactly by "performance issues". I doubt you mean network throughput. Are you able to elaborate?
Re: Music Server
« Reply #8 on: 19 Feb 2010, 08:05 pm »
Hi quietdragon,
I will get you an engineering answer but here is a brief description for you of where we are going - its part of the new literature I am working on:
BRYSTON BDP-1:
The Bryston BDP-1 is designed to interface between your ‘music library’ and a high quality DAC (Bryston BDA-1). The BDP-1 Digital Player has no display (GUI), no hard drive, and no CD drawer or Ripper, and no Wireless Streaming. It runs a very stripped down version of the operating system Linux, with just what is necessary to "play" the files. It has no internal storage. It boots from flash with a read only file system. The box has no moving parts and is silent. It does not have a big touch screen with fancy graphics, it doesn't rip content, manage or clean up your metadata or synchronize with your summer home. Its focused on playing high res files and will support 16 bit and 24 bit files with the following sample rates: 44.1KHz, 48KHz, 88.2KHz, 96KHz, 176.4KHz & 192KHz
james
1ZIP
Re: Music Server
« Reply #9 on: 19 Feb 2010, 08:19 pm »
....and the $64k question is....."what's this puppy going to retail for"??
Sasha
Re: Music Server
« Reply #10 on: 19 Feb 2010, 08:28 pm »
Hi quietdragon,
BRYSTON BDP-1:
james
While the final product remains to be seen, based on the above I would say you are on the right track, this is exactly what is missing on the market, take a wav file from a storage of your choice, create digital signal of low jitter and send it to digital input on standalone DAC of your choice, supporting higher resolution formats (word length and sampling frequency).
The execution will determine how good it is in the end, potentially it could be the device that finally brings performance of computer based audio to top tier.
werd
Re: Music Server
« Reply #11 on: 19 Feb 2010, 08:34 pm »
Hi James
Why would i use this and not my laptop via usb?
Re: Music Server
« Reply #12 on: 19 Feb 2010, 08:45 pm »
Hi James
It will have two types of inputs (USB and Ethernet) - so you can use any hardwired USB output or USB thumbdrive or a hardwired Ethernet connection.
james
Re: Music Server
« Reply #13 on: 19 Feb 2010, 08:53 pm »
Hi quitedragon:
Engineering input:
Wireless isn’t reliable enough for HD audio.
quietdragon
Re: Music Server
« Reply #14 on: 19 Feb 2010, 08:55 pm »
BRYSTON BDP-1:
... and no Wireless Streaming.
So you will have Ethernet support.
I suggested that it would be great if I were able to push content over Ethernet to the BDP-1.
Perhaps you folks are thinking that the BDP-1 will pull content over Ethernet from the server.
Am I mistaken?
quietdragon
Re: Music Server
« Reply #15 on: 19 Feb 2010, 08:57 pm »
I don't care about wireless.
Wired Ethernet support would be more than satisfactory.  I could add wireless support with a dedicated access point if I felt it was going to work out.
skunark
Re: Music Server
« Reply #16 on: 19 Feb 2010, 10:23 pm »
James,
I have few questions that I hope you can answer:
1) Will the music server features also be part of the SP3?
2) Is the Ethernet interface using UPnP and/or Bonjour to discover the files located on a NAS/computer or is there software that needs to be installed on a computer?
Thanks for your time --Jim
Re: Music Server
« Reply #17 on: 19 Feb 2010, 10:38 pm »
James,
Hi Jim,
1. No it will not be part of the SP3 it will be dedicated to the BDA-1 DAC.
2. Your over my pay grade on that one - I will have to ask the brainy engineering guys.
james
nikon
Re: Music Server
« Reply #18 on: 20 Feb 2010, 05:11 am »
James
Couple questions
Will the BDP-1 resemble a BDA-1 with less buttons and a USB port on the front panel
Will it be compatible with BR-2 remote
Do you have ball - park price worked out for it ...  :eyebrows:
Phil A
Re: Music Server
« Reply #19 on: 20 Feb 2010, 05:28 am »
James
Couple questions
James has indicated in another thread the player will cosmetically match the BDA-1
