0 Members and 1 Guest are viewing this topic. Read 30216 times.
I built this 4"x2'x4' and mounted it on a 2x4 backing (airspace). I intend to build a 6"x2'x4' to mount above the bookcase and then build a rectangle shaped trap that will live in the corner, I will move the bookcase out away from the wall about 12 inches. I apologize for the poor quality photos, iPhone.
Have you ever tried flipping the whole room around? It seems from the photos (I might be mistaken) that you could get more of a symmetrical that way, other than the floor, but that could be cured pretty easily with some sort of riser. This would also reduce some of the space behind the speakers which could add bass response as well. Just a though…
Looks great, Kirk, Are you going to place a second panel directly across from that one on the other wall?
That's one way to find things. That said, if it's under control and sounds correct and not boomy at your seat position, you might not need any more.Bryan
once I get them in place I will measure and post the measurements.
Gentleman,The new addition to my listening attic, Revel Ultima Studio 2's. I will post additional photos as I settle in.
Great speaker choice.Seems like a lot of speaker for your attic space...no other place in the house you can use?George
