0 Members and 1 Guest are viewing this topic. Read 14555 times.
Although I am the gambler type, it seems to be that I am appreciative of my life, my house and my equipment. I might need to look for some other piece of gear that will give the rush without the associated, possible catastrophic failure.
FUSES HAVE ABSOLUTELY NO EFFECT ON SOUND.
Robin,12AWG silver plated, Teflon insulated mil spec wire.
Robin,Electrically speaking, silver plating is better because it becomes a better conductor, less resistance. But for the amount that they charge for these fuses, you can rewire the entire power supply with 12AWG silver plated, Teflon insulated mil spec wire. That should have a much greater impact that the short 0.5" fuse. Changing the fuse once again will absolutely have no audible impact. That whole thread is retarded. With your logic then, you can also cut off the transistor legs and solder 10AWG silver wire instead and also cut off the capacitor legs and solder 10AWG wire to them and also the resistors, etc. Oooh, what about the circuit tracks? What if we solder a solid core 10AWG conductor along each track? The problem then becomes that your solid state amp wouldn't even function properly anymore. There would be so much distortion and oscillation.
Robin,Care to do a blind comparison then? I will switch the fuses without telling you which ones are installed and you will tell me if they are Acme, Furutech, or regular. And I will do the same for my aerospace cables, you can put my cables against whatever you have. To make it worthwhile, lets make a $3000 bet, that should cover any travel costs, etc. What do you say?
