0 Members and 1 Guest are viewing this topic. Read 14558 times.
The analysis is fine Kevin, but I am not convinced that all voice coils meet your criteria. So I will err on the side of caution here. The faster the protection works, the better.
I'm a pragmatic guy... I test it on actual woofers. I don't use 80V rails but it works on 1" dome tweeters. I have a 4" full range driver with a 0.75" coil and you can have a full rail voltage on it for about one thousand one, one thousand two... POOF! Twenty milliseconds is plenty quick for any midrange or midwoofer.
Well Kevin I am certainly impressed with your example, but I wouldn't want to bet the farm that many consumer audio woofers would do as well.Like I said, I will err on the side of caution.Regards; Dan Banquer
I've not measured a time constant so I don't know actually how quick they are operating. It may be that they are much quicker than 20mS. All I really care about with my particular amplifier is that it is quick enough not to damage a tweeter. Since all tweeters will have a cap on them you really have to concern yourself with the midwoofers and their power handling is magnitudes higher than a 4-ohm nominal tweeter. I'm quite sure it could blow a ribbon tweeter. I've popped a ribbon tweeter with a test signal getting a FR measurement. You have to measure the things with a cap on them otherwise they become X-mas tree tinsel. In loudspeaker designs though it is safe to assume that all ribbon tweeters will have a cap on them.
Hi,Thinking about the equips failures I have in the past, I see they was four, three in the power amp and one in a preamp, and the fuses and other protections do dot save me at all !!Here are the events:1 - When turn on the power amp I do not heard the usual click and the amp dead, the power-on 15ampere swith broke.2 - In early 1990years, when listen the fateful Klaus Schulze Dig It CD in hi SPL in the power amp stop. An output transistor blows. http://www.amazon.com/Dig-Klaus-Schulze/dp/B0007ZBG2Y/ref=sr_1_1?ie=UTF8&s=music&qid=1266424703&sr=1-13 - In 2005 again in this same KS Dig It CD in hi SPL a Diode in the amp dead.4 - Late 1980years a bad Diode in a preamp under warranty was alterated.I think these NVA amps have smell of real Hi-End music at a affordable price, IF they had Class A output surely they would be a real competitor to the stratospheric FM Acoustics amps, that are ugly looking amps, and the NVA amps have a very discreet and beautiful looking.
You don't say that you had a fire or blown speakers, so I guess the protection circuitry worked. (I don't know what amp and preamp you were using in the past, but I bet you will lose speakers or have a fire in the future if you buy an NVA amp.)
