0 Members and 1 Guest are viewing this topic. Read 14560 times.
Amps without fuses = ignorance. If the amp has no fuses on the rail voltages and something should happen to the amp, your speakers will see a DC voltage of 60-80 volts. This means that the woofers will certainly blow as they don't have a protection capacitor and the tweeter will probably survive.
FUSES HAVE ABSOLUTELY NO EFFECT ON SOUND.
Let me take this one step further. I wouldn't make a piece of a equipment for myself that was a shock or fire hazard, and I wouldn't do that to anyone else either.It's your call.Dan Banquer
So do the experts think fuses on speaker outputs can protect the speakers or are the too slow?
Thanks Dan. I think I am gonna build some fuse boxes into my speaker cables just in case one of my projects gets funky. At least my speakers will survive.
There are no fuses on the speaker output in amplifiers. There is usually a slow blow fuse (main fuse), usually located together with the IEC inlet. And then there are the fast blow rail fuses.
Obviously, Teflon is nice, but it is expensive. Even better is nothing at all, and so Mr. Dunn embarked on this approach, ending up with a large gauge tinned copper wire used to carry all the power supply currents, output currents, and a really rugged grounding system...The result, when one peers into an NVA amplifier, is like nothing you've seen before. Large hunks of tinned copper wire float at various heights around the amplifier, making it truly unique.
Just wondering - if one were concerned about protecting speakers, wouldn't something like this (either built into the amp or in a separate box) be the best solution?http://aussieamplifiers.com/lsp1.htm
"But, Dan ... if there's a mains fuse in place - which is mandatory to gain electrical approval - surely there is no shock/fire hazard?"Fuses really have little to do with shock hazard they are predominantly for fire hazard.Secondly, engineers have developed over time various protection schemes to limit or prevent damage due to assorted forms of failure, but the discussion of this is far outside the capabilities of this forum. If you wish to look into this further you might want to look at some of the things National Semiconductor or Crown has done for audio. In addition, the computer you use has some very sophisticated techniques.Regards; Dan BanquerP.S. Personally I don't think just a fuse at the AC input is enough for any piece of equipment, and there is a huge majority of engineers and safety people who would agree.
Depends on the fuse and the speaker attached to it. If you have itty-bitty woofers without a cap in front of them the thermal capability of the coil is small. You basically have a fuse of some rating in series with the coil and current flowing based upon the DCR of that circuit and the voltage of the power supply rails. The item with the lowest thermal handling capability will pop first. You should design that to be the fuse but the reality is that the designer of the amplifier doesn't necessarily know what is going to be hooked up to the amplifier. The better way is to have a circuit that detects DC on the output of the amplifier and immediately opens a relay, either on the loudspeaker output or on the power supply rails. It is relatively easy to design something that works in mS so you don't fry ANY loudspeaker attached to the output and you lift the rails of the device and somehow indicate to the user that a fault has occurred. You also don't have to use a low impedance fuse which effectively increases the DCR of the loudspeaker cables. You use a relay that has very good contact area and high current capability. There are plenty of relays designed for AC mains voltages and current ratings >20A.
There is one particular problem with the relay approach. Typically relays have somewhere between 12 and 16 milliseconds before they fully engage. With a fast blo fuse the time before the fuse opens can be much shorter if the current is appreciably higher than the fuse rating. Please feel free to check fast blo fuse ratings for more information.Regards; Dan Banquer
