0 Members and 1 Guest are viewing this topic. Read 19583 times.
I use the Shure gauge and think it works fine. This was confirmed in two ways:(1) a buddy brought over his digital scale, and we compared it against several VTF settings that I established with my Shure. In every case, the Shure was w/in .1 gram of the digital. (2) his buddy, someone who sets up tables for a living, swears by the Shure's accuracy and feels a digital scale is not necessary.I mean really...how accurate do you need to get? 100% scientific precision is not needed. Set VTF roughly with the Shure (or any scale for that matter), then make small changes and use your ear to dial it in the rest of the way. My method is to use the Shure to set VTF at the midpoint of the mfrs rec'd range, then go heavier and lighter in small steps and fine tune with my ear. So to answer the OP's question....In my opinion, you will not get better setup results with a digital scale. I would however give greater attention and care to offset angle and overhang. Getting those dialed in properly yields huge benefits. The impact of VTA varies depending on stylus type.
My point was that on initial cartridge setup, getting to a VTF starting point can be accomplished perfectly well with either scale. After that, you fine tune by ear. So anyone can get to the "correct" VTF using either scale, and there is absolutely no advantage to the digital over the Shure.For example, I assume you initially got to your perfect 2.6 VTF by first using your scale to get in the neighborhood. Then you fine tuned by ear. So your ear determined your final and ideal VTF. Someone using the Shure would do the exact same thing, and would get the exact same ideal VTF.Now, repeating very accurate settings is a different story, and this is where the digital scale shows its superiority. Once you know your perfect setting (determined by ear), I agree that the digital scale is much better at accurately measuring it and then repeating it quickly in the future.So to summarize, the Shure is perfectly fine for initial setup, but once the precise sweet spot is known, a digital scale is better for repeating it.
Assuming a tight range for sweet spot of VTF, the Canrong, by the very nature of its mucher higher accuracy (and repeatability within the zone of that higher accuracy) will allow you to get into the right zone much faster with an initial setup to help you pinpoint the sweet spot.
If you believe the sweet spot is narrow, the Shure simply doesn't cut it.
Combine the much higher accuracy of the digital scale within its margin of error with repeatability in that much smaller margin of error and you have a scale which is better for both initial setup and readjustment if you value both accuracy and your time.
What we got here is a failure to communicate!
