0 Members and 1 Guest are viewing this topic. Read 49994 times.
Hi Rick,Did you mess around with a 3 way monitor design for this one? Could there be a kit opportunity there? Might there be a ribbon that could play well with these other drivers? Okay enough questions The good thing is, is that I have the keys to my architectural firms model shop. Personal projects are verboten, but I can make it look like work Have a great day. Paul
Anarchy continues, this time in a 3-way with the Morel dome midrange and a Vifa tweeter.
If this one similar to the RC3R except for the different woofer and tweeter? If so, how does the bass response compare?
More anarchy on the way in the form of a slender tower 3-way with four of the beasts per side...
Did this one ever get built? Sounds incredible for HT, what is the sensitivity?
Didn't notice this topic was updated. What is a good budget range for the three way?
The monitor with two. The Vifa tweet and morel dome seem like a nice combo here.
No plans for anything further with this design as I prefer the new 7" we're using in the MA-1 over the Anarchy woofer for a 3-way.
Ever get those pictures of the three way? What about it do you prefer, cheaper price? Higher sensitivity? I would assume it's not even in the same category in terms of bass output. I don't see much wrong with the Anarchy aside from it's not spectacular sensitivity.
OK, so what is an MA-1?
Very nice. What are the woofers used in this design?
Rick,How would you compare the aluminum cone illuminators to the woofers you're using in this design?
