0 Members and 1 Guest are viewing this topic. Read 41578 times.
For optimal performance and reliability reasons I don't like having a switch in the signal path.
And our latest review...http://www.soundstagehifi.com/index.php?option=com_content&view=article&id=154:selah-audio-verita-loudspeakers&catid=55:full-length-reviews&Itemid=4
I can certainly understand that. It was just a suggestion. So if someone buys your new speakers, are they gonna get the flat response version, or the rolled off version?Ray
Hi Rick,Soundstage measurements of the Raal Ribbon Verita show that the high frequency response starts to roll off after 8 Khz(on axis measurement refer to website below) any particular reason why you design this way for the RAAL tweeter?If I remember correctly when you use dome tweeter on your past designs they show a rise in the high freq. response when measured on-axis. Why the contrast with the Ribbon tweeter?http://www.soundstagenetwork.com/index.php?option=com_content&view=article&id=431:nrc-measurements-selah-audio-verita-loudspeakers&catid=77&Itemid=18
Depends on the tweeter's dispersion over different angles, both horizontal and vertical. With ribbons this can vary for a number of reasons - the transformer, length / width of the ribbon element, faceplate / horn loading, ribbon mass, etc. plus the usual interaction with the baffle. The bass extension also can influence the voicing. An example would be a small mini-monitor where shelving down the highs some might be desirable in order to have good balance over the whole spectrum.
Hey Rick....So what special tweaking did you do to the crossovers on the GTG Veritas?Good cheer,Mud
Hi Rick,Soundstage measurements of the Raal Ribbon Verita show that the high frequency response starts to roll off after 8 Khz(on axis measurement refer to website below) any particular reason why you design this way for the RAAL tweeter?If I remember correctly when you use dome tweeter on your past designs they show a rise in the high freq. response when measured on-axis. Why the contrast with the Ribbon tweeter?http://www.soundstagenetwork.com/index.php?option=com_content&view=article&id=431:nrc-measurements-selah-audio-verita-loudspeakers&catid=77&Itemid=18The Raal Veritas roll off at 8Khz? I though 20Khz was the norm. I'm 52 years old but at my last hearing test the tech said I have the hearing of a dog. Hate to think I'd be missing out on the tiniest tinkling bells etc.
