0 Members and 6 Guests are viewing this topic. Read 1217175 times.
I'm thinking of getting potentiometers that are a little bit less cheesy than the supplied Honeywell ones.Is this a reasonable option?http://www.partsconnexion.com/controls_pot_connex.htmlI don't want to spend megabucks (I would probably get 4 if I decide to bi-amp), but would like something slightly more confidence-inspiring than what came with the kit.
Black in the middle, red on the right as the knob points away from you, white where the non-existent yellow wire is supposed to go.I just found your picture:That is TOTALLY different from what I have, and the instructions I got with the amp. WTF? I am surprised mine works at all.
I would recommend Precision Electronic pots fromhttp://www.tubesandmore.comOnly $9.95 ea.
I've re-connected it the way you have pictured above, and it works much better, not surprisingly. What does concern me is that Tom went to the trouble to print out an email giving very explicit directions to the contrary.
It certainly could be a synergy thing with the speakers. Maybe not even a Class A/B vs Class D thing. Maybe a different Class D amp would drive them better.
Do you have any other 2-way speakers with passive crossover you can try it with? It's just kind of surprising seeing how many people are thrilled with the amps.
Hey guys,Building an SDS 254 kit. I have an email into Tom regarding fuse sizes but wanted to see if anyone else had spoken to him previously. I have a 7amp slow blow fuse. is that too big? My switch is rated for 10 or 15 amps. Hopefully, I'll be done today!!Thanks
Most of what you need you can get from places like www.parts-express.com.Here are a few links to some items...Fuse holderfor fuse
I didn't get any instructions with my amp except how to change from single-ended to balanced inputs. The manual posted on the website is for the older CDA boards with instructions on how to install outboard leds and how to bridge the outputs. And that's it. No info on fuses. No helpful hints. I guess he just assumes the customer will email him. To be fair I bought the boards seperately and I got my transformer directly from Antek. I'm not sure if his complete kits are different.I had to read this thread a lot to gather all of the needed info.Product: A+Instruction Manual: FI'm still thinking about making a manual with full color pics for the forum just because one is needed so badly. When and if I build another classdaudio amp I'll do it.
Here is what he sent me:
So, I have some solid silver RCAs that have been sitting for a while waiting to go in the final chassis. They are lightly tarnished. I ordered some DeOxIt, but it won't be here for a few days. Any ideas on what I can use to clean the connection so I can solder it?Ted
Has anyone put together a big multichannel amp? I've scrolled through about 1/3 of the thread (huge thread!) and about the most I've seen is a 4 channel. Wonder if an 8 channel (4 boards/2PSUs) has been nicely stuffed in a case.
