0 Members and 5 Guests are viewing this topic. Read 1216853 times.
I still don't know what to do with the purple grid wire.
Has anyone installed an IR-activated remote-control relay for a power switch? I'd really like to do this but haven't a clue how to go about it.I recently found this thing on the interweb:http://www.tauntek.com/tinyir2-learning-ir-remote-control-receiver.htmIt seems like the right thing, but maybe a bit advanced for me. Also, I have no idea how to find a suitable relay and to hook the two up.
Thanks, both of you. Those look incredibly helpful. I'll read soon...So, to make sure I am clear on the concept, I am taking my signal from my DAC via my pre-amp, then put it through the miniDSP, and then into the amps? So it gets converted from digital to analogue, then back to digital, where it is processed, and then back to analogue a second time? Wouldn't it be better to process the signal first, before sending it to a single DAC?
For the record there is nothing wrong with passive crossovers. The best speakers I've heard had passive crossovers. Going active can actually be more complicated. I'm not saying you shouldn't do it. Just know it may not be as simple as it seems.
Source > DAC > PreAmp > DSP > amp(s) > speakers =
I don't think anyone said that there was something wrong with them...Yes, it is complicated and will take time and lots of effort. Back to Class D Audio...
Right, but isn't that glossing over what DSP stands for? i.e.,Source > DAC #1 > PreAmp > ADC #2 > DSP software > DAC #3 > amp(s) > speakers =
