0 Members and 6 Guests are viewing this topic. Read 1217176 times.
I would most definitely be willing to add anything on running it on Battery power...
Also, what do you all think about wiring up a switch? Running the battery supply and the SDS board, both boards have switches. I was planning on doing a switch on the PS so that it does not have any current in it when off. Thoughts?Part 2, I have a DPDT On-On switch. How do I wire it
Awesome, thanks! For whatever reason, Trung wired up both sides of the switch where the other side appears to send power to the remote on switch on the PS board, and the first side is wired like yours to the on/off on the PS board...
Tweak first, then solder when you are happy with what you hear. Please let us know, so we can learn from all of your costly and demoralizing mistakes.Seriously, you have nothing to lose by testing first until you are satisfied.
The thought of battery power seems like a PITA but I am sure it sounds great. We'll see-
